Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
4.2 intake help
Old Mar 30, 2012 | 06:09 PM
stevec's Avatar
Exclamation 4.2 intake help
Hi I have a 2000 audi a6 4.2 I want to put a intake on it but they dont make one for it so what do I put in it for a drop in filter? I dont know if the oil off the k&n filter will mess up my mass air flow?
MY stock filter is all messed up with holes in it so i need a new one as it is so just trying to see what i can put in it thanks.
Old Mar 30, 2012 | 09:20 PM
Crisp's Avatar
Yes the oil messes up the MAF. Just get the usual purolator filter and you should be A-Okay.
Old Mar 31, 2012 | 02:57 AM
stevec's Avatar
so just the wix or fran?
Old Mar 31, 2012 | 10:53 PM
crazyquik22023's Avatar
Just use any non oiled filter and it will work just fine.
Old Apr 4, 2012 | 02:05 AM
eatinupyourcivic3386's Avatar
Honestly there are should be two star screws holding the air filter housing together I just took them off and put a specter air filter were that was... It gotta have a adapter tough cause i don't know how wide the pipe is.... But the air filter is only 26 bucks and fit fine.... No problems ...
Old Apr 5, 2012 | 04:51 PM
stevec's Avatar
So you have the 4.2 and you put a cone on it?
Old Sep 8, 2012 | 06:17 PM
92urs4's Avatar
The K&N filter will not mess up you mass airflow sensor. The only way the oil from the filter would get to your mass airflow sensor is by putting too much oil on the filter after you have cleaned it. If you oil it like it was when you first buy it you will not have any problems. My dad has run a K&N filter in his 98 A8 4.2 for years, washed and reoiled it and had no troubles his mass airflow sensor.
David Narez
Jun 26, 2013 09:20 AM
lukestaah
Jul 28, 2012 11:26 AM
ryanjayblair
B7 Models
May 28, 2009 05:13 PM
apg96
Jun 28, 2005 05:34 AM
