Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
cat delete
Old Apr 8, 2011 | 02:10 AM
redaudi18's Avatar
Default cat delete
Hey guys quick question.
First of all i have a 1999.5 Audi a4 I am buying a cat delete and exhaust for it within the next week. I have been having a check engine light issue that comes on about once a week, and its the same code every time. It say catalyst below threshold. I was told this was because my o2 sensor was bad but come to find out i had it looked at and they said it was fine... So my question is when i put that cat delete and exhaust on will i have a check engine light on all the time? or will it just keep coming on if i cannot figure out the problem with the code that keeps coming up? And yes the cat delete has both ports for the o2 sensors.
INPUT PLEASE and thank you
Old May 12, 2011 | 02:51 PM
danny3535's Avatar
I have the same car (mine is v6 awd) and have the same code.
I was wandering where you're going to get your cat delete from?
Also, I assuming our cars will still run fine with cat since a change of backpressure?
All cars are different but I had a Subaru and it was fine catless.
Thanks.
Old May 23, 2011 | 01:33 PM
Classicalbor's Avatar
Generally that code does relate to 1 of 2 things .. one being a clogged or damaged catalyst in the converter or a bad O2 sensor.
Since you said you have a cat delete straight pipe in I imagine that has to means its one of your sensors, most likely a post-cat sensor.
Old May 29, 2011 | 12:10 PM
o0shaw0o's Avatar
Can u cat delete any audi
Ldetter
Jun 26, 2008 03:51 PM
XDREEAMER
Dec 11, 2007 06:12 AM
S4Neil
Nov 11, 2007 10:44 AM
viper9821
Aug 23, 2007 01:03 PM
