Don't laugh... Plastic Intake Manifold ???
I've searched and read that it's a waste of time. I don't care. If I'm on this forum I have plenty of time to waste
Hoping to squeeze some extra HP out of my 2.8 I ordered phenolic spacers from 034. Then I saw an intake manifold on ebay and made an offer for like $40 and won. Other than cleaning the crap out of it (inside and out) and painting it I thought maybe I can do something to it to get a little more air flow.
My uncle the mechanic says that if it's clean like new that should help some. My idea is to use a flex bit and bottle cleaners with carb cleaner to get the tubes all clean. Then maybe hit the exhaust pipes with some sandpaper and buff them out afterward. Any suggestions?
I'll take pics and I guess we'll see what happens.
Not interested in hearing the antics of those of you who have nothing nice to say.
TIA
TIA
Thats what I was thinking. I think if you polished the runners then at the botom ruff them up with sand paper. Apparently you want the air to be turbulant to help mix with the fuel. ALso Somewhere around here I think it was on this site someone was doing a pretty good study about adding material to the intake runners becasue if the port was smaller the air would have more velocity. Apparently it worked on some race bikes and such. Anyway good luck.
Didn't mean to confuse. I want more air. The ebay mani is a stock one that I can work on in the meantime and hopefully not ruin. I was hoping by slightly porting the bottom ends I could get more air to flow. (But I do know I have to be careful with plastic). The intake runners seem to be smooth enough bcuz it is plastic.
SO leaving it rough at the end would help?
I think I recall reading that thread too, about adding material to the intake runners. I'll search but if you find it I'd appreciate it.
Not to be a buzzkill, but, lemme see if I understan what you (two?) are attempting...
You are hoping to, by error (I'd say, "trial & error but you just have the one intake to screw around with), achieve some sort of "ram-tuning" effect (google it), to increase the airflow and thereby the CC turbulence? Hoping, I presume, to increase your performance and/or mileage by dint of some sort of engineering/tuning epiphany heretofore un-discovered by tens-of-thousands of years of collective auto industry engineering schooling and billiions-of-dollars of auto industry R&D?
OK!
You'll need some of these tools, to help you in your process:
A Pilot Wrench
Don't forget to get a Boost-Bar
You may also wanna pick up some Adjustable Power Bands
Spark *Plugs* will help ignite your newly turbulented fuel-air mixture
And, you'll need PLENTY of Elbow Grease, to muscle your way through those tough-to crack Nuts & Bolts
Oh, and, when you're done, don't forget to dyno, to verify your results
Next week: Cosmetic & Appearance upgrades
Stay *Tuned*
OK!
A Pilot Wrench
Stay *Tuned*
LOL. the jerkys on this forum are entertaining.
SO I start today I'm going to start to clean this thing because there's a ton of residue in it. I'll probably spray it down with some engine cleaner then power wash it all out. Next, I found an extra long pipe cleaner that I'm looking to run through the runners with some carb cleaner until it's all clean. Last I have a 14" flex bit I'm going to attach to either an air tool or drill with a dremel sandpaper bit and go half way up the exhaust port...
TBC
TBC
Hey 2.8Luv, glad you saw the humor, and not hate.
N-E-way, with apologies for the fun at your expense, most of my post was directed at superdug's missive. Seriously, you are basically trying to "improve* on something that has been designed by millions of dollars of R&D money, with a dremel-tool, carb-cleaner and some sand-paper. There is more to "combustion-chamber" turbulence than simply disrupting the airflow. If that were the case, smoothing out the upper portion of the runner would be counter-productive to what your stated goal is, true, or am I mis-reading?
Same with the dug's theory about adding material to the runners. If true, using a narrower intake would mean extra "free" super-fast airflow and there'd be millions of websites dedicated to how best to choke your intake for the "fastest" air!
I wasn't kidding when I said you were hoping to come up witha solution that all those other guy's schooling & coporate deep pockets hadn't. I mean, if you were using some sort of CAD program, and had scanned in your intakes profile, crunchin some numbers... Maybe.
Anyway, you're gonna go ahead with it, anyway, I know, because *I* was young, once, too.
Good luck!
Stay in school!
Keep us posted.
Good luck!
Stay in school!
Keep us posted.
Sorry been a way for a minute but in response to my earlier post. By the way I do see the humor in your post and I take it in Gest but what i have found is that generally those millions of dollars of research have gone into some engineers pocket and generally enginners all think inside the box. Now I don't have any formal schooling to speak of on cars or any proper knowlege on engine therory. All i have is a decade or so of building motors for race cars and street cars. and believe me I don't know everything and don't claim to know everything. The fun part here is you have an intake manifold you can screw with and try new things. just as an example that somehow all this miollions of dollars of research missed was if (only good for headers) but you can weld a flat plate in your headers dialed in to a very certain degree depending on the motors there was anywhere from 3-5% power increase. just by welding a simple plate inside your header. I know it's weird that some backwoods boys without a big fancy shop could figure this out but it happened. So back to what I was saying is that on our intake manifolds for our race car we would port and polish the intake then match our heads and gaskets so there was no way for the air to slow down. then at the bootom of the intake manifold we would just roughin up the runner not even a lot but it would disurb the air just enough to help it mix with the fuel. We had good results with it. Then I read that article about adding material it was on Race bikes agaian unproven bu the therory was sound and by starting off with the normal size runner then making it a little bit smaller at the end effectivly sppeding up velocity you could cram more air into the cylinder. Were not talking about a great deal either way, changing thinngs minuetly could alter the performance of the engine.
Side note is that i am not saying that anyway is right or wrong and most of what we have done has been off of our racecars with v-8's sometimes big block sometimes small blocks. And for our cars could be for better or for worse all I know is that nothing ever changes if you don't think outside the box.
