Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
HELP!!! Audi A5 P2279 intake air system leak
Old 05-15-2019, 10:27 PM
Mikey330's Avatar
Exclamation HELP!!! Audi A5 P2279 intake air system leak
When I turn on my car it idles rough and turns on the check engine light. I ended up going to Audi dealer for a misfire-code P0300, P0301 and P2279. The dealer said it was the Upper timing cover needs to be replaced it was leaking air and was causing for the car to misfire. I ended up doing the upper timing cover replacement. car runs more smooth then before and no check engine light. But when I got home I plugged up my ob2 reader and then code P2279 shows up but theres no check engine light. what should I look for PLEASEE HELP
side note
AUDI A5 2013 2.0t quattro
spark-plugs and air filter were just changed a week ago and a month ago high fuel pressure pump.
Old 11-29-2022, 04:53 AM
Default Fault code
Maybe they didn’t clear all the faults after completing the work. Try clearing it and try again in a day or two to see if it comes up again.
amirmehrabi
10-08-2019 11:32 PM
MadRussianA5
05-05-2018 08:49 PM
TAGANROG
05-22-2010 09:14 PM
MasterV
03-14-2007 06:52 PM
tha5150
07-13-2006 03:35 AM
Quick Reply: HELP!!! Audi A5 P2279 intake air system leak
