Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
k03 turbo
Old Jul 20, 2009 | 12:35 PM
CTFRunN3r's Avatar
Default k03 turbo
what is the max boost that i can get out of a k03 turbo?
Old Jul 21, 2009 | 08:11 PM
sluggerjd's Avatar
around 18 without killing all internals.
Old Jul 22, 2009 | 08:16 AM
CTFRunN3r's Avatar
im running 19 now. and the turbo sounds like it just about had it.
Old Jul 27, 2009 | 10:13 AM
vishnu333's Avatar
Default 18psi seems about right...
I am getting max sustained of 15 psi and spikes of 16-17psi, as read from a VDO mechanical boost gauge. I plumbed my gauge right off the manifold, after the throttle valve. I have the stock k03(s) turbo with an O.CT chip/program. Not sure if you are asking about a K03s or K03? Don't know how much pressure drop there is across the stock SMIC or how high that program is trying to push the boost in the first place. So I might be spiking around 18-19psi at the compressor outlet. The car as been running this setup for over 40k miles. Hope that helps.
Old Jul 30, 2009 | 04:36 PM
Mike-2ptzero's Avatar
All of you are wrong lol
I ran 26psi on my stock K03 that came with my car, that was on a custom GIAC chip for CA 91 octane.
Old Jul 30, 2009 | 05:22 PM
AutoUnionFan's Avatar
what kind of power were you making? how long did the turbo last?
and why would you custom tune a K03? lol
Old Jul 30, 2009 | 07:09 PM
Why a custom tune? Because it was free(sponsored) and because my custom race tune pushed out 250chp with a K03 and ran 14.29 at 97 mph which still holds the A4 1.8t K03 record since 2001. lol
You can find it on this very old 1/4 mile B5 A4 list. http://timeslips.bootnetworks.com/
Here is my actual K03 time slip from back in 2001.
The funny part is that my K03 on a earlier custom file I was able to put down as much tq on a dyno as a APR Stage 3 on a race tune put down right after I got off the dyno. That car was even brought to the event by APR since it was owned by an employee and they were using it as R&D for tuning.
Actually I pushed that k03 hard for over a year, even took it to the drag strip every single weekend and some times even more then 1 day at the track for 12 months before I removed it for a GT28r setup. I ended up selling that turbo a few years ago to someone I knew and he still has it on his A4.
Old Jul 31, 2009 | 11:27 AM
damn Mike, you are a legend
did that custom tune build boost slower than a generic GIAC file that you buy online?
I dont understand how you didnt destroy that poor little turbo
Old Jul 31, 2009 | 12:45 PM
Well spool up is all based on tuning, but you really cant get a k03 to spool up any quicker then it already does without increasing displacement. A race tune will get it to spool up a little quicker since the motor makes more power on its own because of the added adv timing and higher octane.
My custom tune was tweaked to allow the throttle body to open much quicker as I hit the pedal.
The custom 26psi street tune I was running ended up being used to produce the J31 K04 file for the 2000 which runs around 28psi but works best when ran at 25psi.
Old Mar 26, 2011 | 05:13 AM
BlueBoostedaudi's Avatar
The custom 26psi street tune I was running ended up being used to produce the J31 K04 file for the 2000 which runs around 28psi but works best when ran at 25psi.[/QUOTE]
Mike, so I got a 2001 audi a4 1.8t AWM block with AEB HEAD big port n polish with precision 5758 .63a/r turbo, greedy BOV, godspeed headers, 3" cat back exhaust, 2 1/2 piping kit & intercooler, water n methanol injection(comes on at 9psi), adjustable timing gear, and everything else is stock. how much boost can I run safely with out blowing my motor? And what tune would you recommend? How much timing can/should I advance it?
