Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
test pipe error codes
Old 04-15-2010, 09:52 PM
D.B.A.'s Avatar
Member
Default test pipe error codes
I have a 2001 A6 2.8 that i took the cats off of. Basically what i did is make a homemade test pipe.... I just cut the cats off and welded a angled pipe in their place. Put the non fouler trick in place. Basically a test pipe but home made.
With that being said, I keep getting error codes.
Code:
P0170 Fuel trim (bank 1)
P0160 O2 Circuit no activity detected (bank 2, sensor 2)
I have tried various things to fix that like backing the O2 sensor further away from the flow and angling it back but that gave me more codes(pic 1) also tried using one non fouler(pic 2) with no luck.
the passenger side is giving me the P0160, which is the right side(passenger) Pic 3 is just a pic of the setup
Im starting to gather my own opinions but I want everyone's input first...
Attached Thumbnails test pipe error codes-img_1613.jpg   test pipe error codes-img_1616.jpg   test pipe error codes-img_1622.jpg
Old 04-16-2010, 10:44 AM
Mike-2ptzero's Avatar
Are the pictures of just the post cat 02 sensors location?
Old 04-16-2010, 09:51 PM
D.B.A.'s Avatar
Member
yea those pictures are of the post cat O2 sensors
Old 04-19-2010, 11:15 AM
D.B.A.'s Avatar
Member
anyone got any ideas on why most test pipes out there work without throwin a code but mine doesnt???
Is that fuel trim bank 1 code even related to a converter???
Old 04-19-2010, 11:44 AM
No that code is not related ot your test pipes since it is for the precat 02 sensor. You either have a bad 02 sensor or a fueling issue on that side of the motor.
What was the complete code and have you looked at the fuel trim readings to see if they are way off for that side?
Old 04-21-2010, 11:25 PM
D.B.A.'s Avatar
Member
Ok im getting a bank one malfunction error... the other one is the exact code.
I havent looked at the fuel trim readings how do i do that?
Also i heard from the dealer that bank 1 is the drivers side.... but i saw that bank one was passenger side on here... which is which?
Old 04-22-2010, 10:05 AM
Should be block 032.
Old 04-23-2010, 10:06 PM
D.B.A.'s Avatar
Member
can you ellaborate? block 032???
Old 04-24-2010, 12:20 PM
They are the fuel adjustment readings, so basically tells you how much fuel the ecu is adding/removing at idle and part throttle based on the 02 sensor readings.
Old 04-27-2010, 04:32 PM
D.B.A.'s Avatar
Member
so im assuming i have to have a vag com to test the readings huh?
Quick Reply: test pipe error codes
