can i add subwoofers to my stock a4 head unit?
got a 2005 audi a4 s-line quattro with the bose system.....wondering can i add 2 12" subwoofers to the stock headunit with a amp that i have also that works with the subs? if its possible what is required to do hook it up to the stock hu....do i need any special module or can any audio shop simply wire it up?
No you dont need anything special.. But the shop will most likly charge you an arm n a leg to set it up for you. There is a lot of wiring work involved. Honostly, I wouldnt mess with that or change it. Stock system sounds good as it is. Plus, if they mess up they could totally screw up your car's computer and alarm and such... not worth it
What exactly do you need? Ive been wanting to hook up a sub and amp to my stock headunit for awhile. Do you just run the wires under the carpet and which wires do you tap into behind the stock stereo unit?
there is a few ways to do it, and noone has explained any of them to you thus far. line level input is the cheapest and somewhat easiest way. poor quality sometimes. you can also get a unit from JL audio that lets you add amps so you can get signal from RCAs instead of speaker wires. plus you can tweak it to perfection without tapping into your factory wiring. HTH
