Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Door pad removal
Old Dec 15, 2012 | 09:13 AM
Atcrider1's Avatar
Default Door pad removal
Hey guys new to the forum and new to audis. Bought my first audi, an 02 a4 quattro 1.8t. One problem I have it the window switches fell into the door pad. How does one remove the pad to reattach the switches? How do they attach?
Thank
Cody
Old Jan 7, 2013 | 03:17 AM
lukestaah's Avatar
Remove the two visable screws at the upper corners of the door panel. Remove the screw in the armrest, inside the grab-handle area. Now remove the oval-donut trim piece that this screw was holding inplace, by snapping the trim piece downward. This will expose two screws; remove them. The door panel is now removed by lifting it upwards, then out. You'll need to disconnect electrical cables and unhook the door latch cable. Then just find the door switch that fell out and put it back in. Not sure what side goes in first but you should be able to notice it once you find the piece. Then reconnect everything back together and snap the door back in.
Atcrider1
Dec 17, 2012 03:47 PM
Mac_17
Oct 29, 2007 04:41 PM
auS4di
Jun 22, 2006 09:16 PM
Soley4pres
Dec 10, 2004 02:09 PM
sharkbait
Sep 7, 2004 12:17 PM
