Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
how do i get the door panels off
Old Apr 11, 2005 | 08:11 PM
audiboy4life's Avatar
Default how do i get the door panels off
hey i finally just got all the part of my sound system, i installed the rear self but i dont know how to get the door panels off to install the door speakers? and anyone help me? greatly appreciated thanks rick
Old Apr 12, 2005 | 02:39 AM
jent's Avatar
Default RE: how do i get the door panels off
not sure on the front but I just removed my rear door panales. They were a snap. There was a screw at the top left and top right corner you removed. Then you removed one inside the handle, it is on the left side of the inside of the handle. Once you removed that there is a plastic peice that it was holding in. You don't even need to remove this part you can just slide it down a little and you will notice the last screw inside that plastic peice. Remove it and you can pull up the door panel stright up and then pull it away from the door. Carfull for the attached wires and what not.
Old Apr 22, 2005 | 02:14 PM
wrax's Avatar
Check the DIY section... I wrote this...
https://www.audiforums.com/m_64789/tm.htm
something similar I guess on all models
Old Jul 25, 2005 | 06:37 AM
Audi4Life's Avatar
Well, that all was informative... is it universal on all years? I have a 93 100... and I need to replace the window regulators on the passenger side... also, I want to make the rear windows go all the way down, and put auto buttons for the rest of the window and not just the drivers...
Old Aug 2, 2005 | 08:42 PM
Legaumais's Avatar
Here for Audi 100:
Old Aug 2, 2005 | 08:44 PM
Legaumais's Avatar
Bye!
Old Jan 20, 2006 | 11:28 PM
lynx711's Avatar
how about for a CQ. I need to replace the window regulator on the driver's side and the door handle on the passanger interior door handle isn't connected to the wire thing in it. Anyways, I have a feeling it's very similar
jacobennis
Jun 15, 2009 09:43 PM
guru_king423
Sep 20, 2008 01:00 PM
tophubufu
Aug 13, 2008 03:55 PM
matthias2986
Jun 16, 2007 10:46 AM
02TurboA4
Aug 2, 2006 07:35 PM
