Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
How to remove interior panels
Old May 25, 2015 | 12:33 AM
Nielsterp's Avatar
Default How to remove interior panels
Hi, I'm having a small problem with my Audi A6 Avant stationcar from 2000:
The seatbelt in the drivers seat was twisted, and as many has observed, it was totaly impossible to twist the belt and squeze it through the buckle. So I got the "engineous" idea to pull the belt completely out, twist it and then squeze it back through the hole where it comes out.
It worked - sort of. Now my belt is not twisted, but it is also not retracted as it was before, leaving most of the "used" belt hanging in the cabin - and often being stuck in the door when I close it.
Even if I pull the belt max. out, I can not get the twist out again.
So how do I unmount the fiber panels that cover the belt mechanism ? This will include the part where the belt is adjusted in hight. I don't see any screws - is it simply a matter of "breaking" the panel loose with a screwdriver, or will that mess things even more up ?
Hoping for a little help before I seriously break my Audi !
Old May 31, 2015 | 01:01 AM
Nielsterp's Avatar
Default Friendly bump
bump !
Luispv
Jun 24, 2018 06:13 PM
SSEI173
May 20, 2015 09:15 PM
lifethrasher
May 24, 2009 02:55 AM
digital0101
Feb 19, 2007 07:10 PM
nrosei4
Oct 20, 2005 06:11 AM
