Replacing 2001 A6 Quattro Radio with a Double-din in-dash Navigation/DVD receiver
Hello fellow Audi lovers and experts
A couple of days ago, I ordered an In-dash Navigatopn/Multimedia system to replace my radio on my 2001 A6 Quattro V8. I am a total noob which means this is my first car ever and I have no clue about it. Once I receive the package, I am planning to go to a local car stereo shop to install it for me.
The new system is double-din. Would that be a problem?
Second question, do I need to buy anything else for the shop to install it? Like a new dash kit or a trim or anything?
Much appreciated.
Much appreciated.
First of all, welcome aboard!!
I know my reply might be a bit late, but I was just curious about a couple of things.
First, is the In-dash Navigatopn/Multimedia system you purchased OEM or aftermarket?
Next, is your current radio single-DIN or double-DIN?
I was just curious because I recently replaced MY radio in my 1999 A6 C5 with an aftermarket In-dash Navi system (Pioneer AVIC-X940BT), and had to jump through a few "hoops" to make it work, as my OEM radio was the single-DIN Concert II system.
If your current radio is already double-DIN, then you shouldn't have much of a problem with mounting the new deck. I can think of a few things that you might have to look out for, but not off the top of my head.
Hit me up if you have any questions.
Thank you for your reply. I have already purchased the radio and installed it but I regret doing it so fast and spending a lot of money on it. So initially, I did not understand the difference between the aftermarket device and OEM. Mine turned out to be an aftermarket system. That required me to buy dash kit that cost me $50 and a harness and the total cost of installation was $160. The radio is very bad and unclear, and the GPS does not search for places.
$160??? Holy buckets! We don't even charge THAT much for a deck install at the shop I work for. Heck, even doing my side 'work', I only charge $45-$55 (not including parts) for just about any deck install that doesn't require major modifications. I probably should've told you to take the 2 hour drive to Bend and have me do it for you. BTW, what was the manufacturer of the aftermarket system you got? I'm just a tad curious.
@nubiannupe: If I had known I would definitely have driven to Bend for that. The unit I bought was not really good. The radio is always fuzzy and not clear, I can not search for places using names just actual addresses with the GPS. The brand name is Lanzar and I got it for $192 from carid.com.
wingluk
Sep 4, 2009 12:41 PM
will_pankey
Jul 14, 2007 02:02 AM
