Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
RS4 Recaro Seats vs Mazda RX8 Recaro Seats
Old Jan 14, 2012 | 06:52 PM
TURBO_S2K's Avatar
Default RS4 Recaro Seats vs Mazda RX8 Recaro Seats
I found a good deal for some brand new Mazda RX8 Recaro Seats. They do look a lot like the B7 RS4 Seats
I know they are not identical but I want to know if the sizes are the same. The RS4 seats from pictures do look a little muscular and larger but it might be from the picture angle
The headrest area is a little different but size and width wise I am wondering if they are the same.
If so, I will get the set and install them into my B7 2.0T
Here are the pics to compare...
Audi RS4
Mazda RX8
Old Jan 14, 2012 | 06:58 PM
turbo kraut's Avatar
Tech Guru
Just get what you like cause you'll have to fab anyways
Old Jan 14, 2012 | 07:44 PM
TURBO_S2K's Avatar
I am hoping it won't be too hard to fit
planning on installing the recaros on the oem seat mounts
Old Jan 14, 2012 | 09:01 PM
etzbseder's Avatar
I like the looks of the mazda ones, but he RS4s are probably more comfortable to sit in since they're a little wider at the shoulder.
Old Jan 15, 2012 | 07:40 AM
TURBO_S2K's Avatar
that is my main concern
the rs4 seats are wider and look muscular
the rx8 looks really good inside an rx8 but i am concerned that the seats won't look as good as in rs4 because of the size
Old Jan 16, 2012 | 05:06 PM
pa4ul's Avatar
i thought that the recaros are fit directly onto the car with no modification? or is that only the b6 recaros? I know u might have to fidget with wiring but i thought it was nearly a direct swap?: As for the mazda ones i have to say u will definatly need modification.
Old Jan 24, 2012 | 12:47 PM
TURBO_S2K's Avatar
the best way to find out was to do it and see
very satisfied with the results...
Old Jan 27, 2012 | 10:42 PM
ImTheDevil's Avatar
They look really good. Info on what the swap entails?
Old Jan 29, 2012 | 11:30 PM
RomanNY's Avatar
My bud use to have an rx8 the recaro's feel pretty alright, they're tight but i would probably go with the rs4's because they'll most likely fit without modifications
Old Feb 10, 2012 | 05:52 PM
TURBO_S2K's Avatar
Best deal I found on the RS4 seats were $6000
I got these for $1000
It was worth spending 2 hours on installation rather than paying $5000 more
