How to?Replace Trans Fluid, lower oil pan gasket, and oil temnp sensor...
Old Feb 28, 2008 | 11:41 AM
sautsinaga's Avatar
Default How to?Replace Trans Fluid, lower oil pan gasket, and oil temnp sensor...
Hi guys..
I need some help on installing
1.A new oil pan gasket
2. Replacing my Transmission Fluid
3. And replacing my temperature sensor and where it is?
Can somebody help me out on this. I'm trying to cut the cost from going to the mechanic, besides I kinda like working on cars though I dont really know much about fixing cars. I just learn as it goes. hehe.
If somebody could give me a step by step instruction and what kinda tools I need, what are the do's and dont's, I would really2 appreciate it.
I have a1996 A4 Quattro 2.8L
Thank you all....
Old Feb 28, 2008 | 11:54 AM
CAB509's Avatar
6th Gear
Default RE: How to?Replace Trans Fluid, lower oil pan gasket, and oil temnp sensor...
welcome
oil pan gasket, shouldn't be that hard, just drain oil/ take of the oil pan/ scrape of the oil gasket/ put new one back on/ replace oil pan/ refil car with oil (what a great time for an oil change)
Trans Fluid - https://www.audiforums.com/m_156758/tm.htm
I'm not sure where the temp sensor is but I know the thermostat is behind the timing belt if that helps.
Also if you poat this in the A4 section you can get more help.
Old Feb 28, 2008 | 12:53 PM
sautsinaga's Avatar
hey, thanks man, ive already posted it under a4 forum
NoAudiGuy
B7 Models
Dec 16, 2016 05:13 AM
yellow_submarine
Feb 3, 2011 04:25 AM
jseel
Oct 19, 2010 11:06 PM
verderacer
Apr 22, 2008 06:05 PM
sautsinaga
Feb 29, 2008 02:25 PM
