Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
2001 TT 1.8 Turbo Problem
Old May 8, 2010 | 05:52 PM
JETSPEED333's Avatar
SoCal Crew Member
sounds like your ready for a chip =)
Old May 24, 2010 | 04:00 PM
R.A.I. Motorsport's Avatar
Former Sponsor
If you're referring to "cranking the wastegate" its not a good idea. A chip is the best mod you can get for your car
Old May 31, 2013 | 08:27 PM
Beast_tamer's Avatar
Default Turbo issues
Seems a lot of you are all having the same problems I've just had with my Audi TT mine is speed chipped and now 230 bhp the yellow emissions light came on on the dash board but because i spent 3 years at college in mechanics had to break down the problem stuck it on diagnostics tester at my college where i did my course and it came up with N75 solenoid valve (You will find this just above the spark plugs its a 3 way adapter that links up the air to fuel ratio to ur turbo has the pipes coming off it that might need changing its a simple 5 minute job to do with some pliers for the pipe clips but a costly £62 for the solenoid valve from euro parts. checked spark plugs as these often need replacing with it being a sports car and maybe check the coil pack as that could be a big cause of the issue I've replace the spark plugs and coil and n75 valve and everything is now running smoothly again as before that the car was running like a bag of s**t and wasn't idling at 1000 rpm was bouncing around all over the place and diagnostic tester showed that it was mis-firing on all cylinders due to the n75 valve not being able to do its job due to malfunction.
i hope this helps
xjcody10x
Feb 5, 2010 11:33 AM
JDB
Jan 21, 2009 05:18 PM
JDB
Jan 19, 2009 09:54 PM
auditech79
Sep 7, 2008 08:39 PM
audi4s
Aug 4, 2006 10:34 AM
