Ko4 or ko3 ported, polished and clipped
Ok, Is it worth having your turbo ported,polish and clipped(compressor wheel), vs. paying 1700 for the total ko4 and software. With the ko3 you could keep your old software also,right?
RE: Ko4 or ko3 ported, polished and clipped
I woould think you'd need software either way. Your getting more air through in both cases, which will require more fuel in order not to run lean. The fuel mapping portion of the chip would address that. Have you seen these two options compared anywhere? It's be interesting to see what kind of hp each would render.
A comparrison would be nice. BUt porting and polishing and clipping the exhaust wheel, is an unconventional "Audi" way of gaining horsepower. ANALOGY:
KO4 ---> CHipped ecu
AS
P+P+C KO3 ---> Boost controller + fuel computer
Me, being the cheap bastard that i am, would rather Port and clip my KO3 then spend some money and get a KO4. I would rather buy a boost controller and fuel computer than have the tried and true security of a very well researched and tested, ecu upgrade.
AS
do apexi SAFCs work on these cars? thats what i was using to control my honda(that and i was experimenting with uberdata) if these work on audis then i could probibly figure out how to run what we call an safc hack, basically using some weird settings to allow the factory computer to control bigger injectors, which in term allows for boost, or in audis case more of it.
