Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
Ko4 or ko3 ported, polished and clipped
Old 08-23-2004, 04:53 AM
audiboy1618's Avatar
Default Ko4 or ko3 ported, polished and clipped
Ok, Is it worth having your turbo ported,polish and clipped(compressor wheel), vs. paying 1700 for the total ko4 and software. With the ko3 you could keep your old software also,right?
Old 08-23-2004, 11:37 PM
Doose's Avatar
Default RE: Ko4 or ko3 ported, polished and clipped
I woould think you'd need software either way. Your getting more air through in both cases, which will require more fuel in order not to run lean. The fuel mapping portion of the chip would address that. Have you seen these two options compared anywhere? It's be interesting to see what kind of hp each would render.
Old 08-24-2004, 08:38 PM
A comparrison would be nice. BUt porting and polishing and clipping the exhaust wheel, is an unconventional "Audi" way of gaining horsepower. ANALOGY:
KO4 ---> CHipped ecu
AS
P+P+C KO3 ---> Boost controller + fuel computer
Me, being the cheap bastard that i am, would rather Port and clip my KO3 then spend some money and get a KO4. I would rather buy a boost controller and fuel computer than have the tried and true security of a very well researched and tested, ecu upgrade.
Old 08-26-2004, 11:22 PM
So your running 12.59s without a chip?
Old 08-27-2004, 07:45 PM
I use a boost controller and a stand alone fuel computer
Old 09-04-2004, 07:38 AM
ImolaS4's Avatar
Just an FYI: With a turbo upgrade you will need new management software.
Old 09-07-2004, 01:37 AM
geez, so much for a little big compressor wheel.... is it worth it?
Old 09-07-2004, 02:24 AM
Thats for you to decided.
Old 01-06-2005, 06:34 PM
greenday's Avatar
do apexi SAFCs work on these cars? thats what i was using to control my honda(that and i was experimenting with uberdata) if these work on audis then i could probibly figure out how to run what we call an safc hack, basically using some weird settings to allow the factory computer to control bigger injectors, which in term allows for boost, or in audis case more of it.
Old 01-10-2005, 12:47 AM
yeah but there a pain in the ***
Quick Reply: Ko4 or ko3 ported, polished and clipped
