Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
please help!! code p0299 pending
Old May 28, 2010 | 01:05 PM
myblueaudia4's Avatar
Member
Default please help!! code p0299 pending
hey all... so i got the cel pulled the code and got p0299... changed the dv and reset it. came back on this morning after driving about 10 or so miles. what else is there to do? this recently happened after i got the apr upgrade .. is there anyway i can clean my o2 censors myself and try and do process of elimination. id rather not go to the stealer..
thanks for everything.
Old May 29, 2010 | 08:00 AM
makav3li's Avatar
We need to know what kinda car you have to begin with...
16683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached
Possible Symptoms
* Reduced Power Output
* Limp Mode
Possible Causes
* Hoses/Pipes incorrect connected, disconnected or leaking
* Charger Pressure Control defective
Possible Solutions
* Check Hoses/Pipes to/between Components
* Check / Clean / Replace Charge Pressure Control
Special Notes
* When found in 2.0l TFSI:
o Check Boost Pressure Control Valve (N249), for cracked rubber diaphragm. A new/optimized Valve is available under Part # 06F-145-710-G (or newer), see TPI 2016331 for details.
This is the basics
Old May 29, 2010 | 11:12 AM
Member
Default more information
hey thanks for the reply..
2003 a4 1.8t quattro 58k miles
afe cold air intake
magnaflow exhaust
and just recently the apr flash upgrade.
im going to check for leaks today
Old May 29, 2010 | 11:46 AM
Member
Default some pics
i found a hose by the intake wrapped with tape
and another by the engine wrapped in tin foil?
Attached Thumbnails please help!! code p0299 pending-img00068-20100529-1126.jpg   please help!! code p0299 pending-img00070-20100529-1128.jpg
DonnieB2
B7 Models
14
Sep 21, 2017 09:50 AM
captainawesome
Feb 17, 2012 11:48 AM
myblueaudia4
May 28, 2010 01:08 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
b6driver
May 30, 2006 05:11 AM
