Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
Replacing K03 with K04 turbo
Old Jan 1, 2009 | 06:33 PM
IcemanS4's Avatar
Default Replacing K03 with K04 turbo
hello i was wondering if anybody could give me some advice.. i recently blew my k03 turbo on my 2001 audi a4 1.8L. i have purchased a k04 turbo. and i want to no what im going to need to make this fit. thanks
Old Jan 1, 2009 | 08:17 PM
cincyTT's Avatar
I'm make believe
If you spend 2mins searching, you would learn that they are basically interchangeable and since you have an 01, you just swap them and your done
Old Jan 9, 2009 | 02:04 PM
matasci's Avatar
its a direct bolt on more air means more fuel dont know much after that. higher pressure reg. programming for new turbo, new dv, that should do it.
Old Feb 7, 2009 | 10:30 AM
jim1000's Avatar
Smile
they just swap straight over at least me aeb a6 did was flowing 216bhp on standard 150bhp audi map, and around 260 with custom chipped uk map, just changed for a forge 007 dv to cope with extra boost just changing over to full sillicone piping to help with boost leak .
Old Feb 9, 2009 | 12:15 PM
bemor187's Avatar
Well you are going to need to be chipped with a Ko4 file and you should golden.
You can just stick it in there with no file, but you are unlikely to get much more power out.
I would personally suggest giving me your turbo. but you prolly wont go for that soooooo.
You will want to get some Bosch TT225 injectors and the file for that via the chip. Then you are looking at a 40hp increase.
Old Feb 10, 2009 | 05:47 PM
boostedride111's Avatar
retune for the larger turbo. With 40HP you can probably get away w/o larger injectors maybe just bump the fuel pressure a little - but you'll still want to retune...
Old Feb 28, 2009 | 10:25 AM
Pumpinstrong's Avatar
I am looking to do the same thing, I'd like to change the K03 to a k04. Does anyone know where I could get some part numbers for the k04's?
I have an A6 2.7T btw.... 2004. Anything I should do prior or after swaping?
Old Mar 4, 2009 | 02:12 PM
02AvantImola's Avatar
Make sure you get the right flange for the turbo. They are different on for the 1.8 than the 2.7. Search Ebay for an OEM K04 turbo, and if it looks like it is a good deal and its new, more than likely its not OEM.
Old Jan 4, 2010 | 12:38 PM
cmaust's Avatar
i know this is a very old thread, but i didnt want to **** people off by making a new one
i have an 01 2.7t, do I have to buy a kit with the intake pipes or do i just need something like the second one
http://www.ecstuning.com/Audi-C5_A6-...bo/K04/ES1372/
or
http://www.ecstuning.com/Audi-C5_A6-...rbo/K04/ES470/
edit: i just stumbled across this website, http://www.gpopshop.com/rebuilding.html
is getting turbos rebuilt a good idea? its sort of a last resort as I am very strapped for cash at the moment, but if its pointless id be willing to just hold off until I could get a kit.
Old Apr 1, 2013 | 12:23 PM
Mrmarcb6's Avatar
I just got a k04 is it going make any diff from ak03
Or am i just throwing money away
