Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
View Poll Results: A poll
M45
10.00%
M62
12.50%
M90
20.00%
M112
20.00%
forget the audi get a musle car !!!
37.50%
Voters: 40. You may not vote on this poll
Super charger
Old Nov 9, 2006 | 04:16 PM
  #71
kakarot's Avatar
Default RE: Super charger
I plan to start off at about 2 psi just to see how everthyng works together. then move up. up to 10 psi which audi can support w/intercoolling. In any case, you can do about 325 to 350 HP but thats a border line with pump gas.
the CFM dipends on the displacment of the engine, boost and RPM.
I do not go into the CFM, I just keep around boost and RPM.
the CFM can show you how much potential power can be produced.
Old Nov 9, 2006 | 05:29 PM
  #72
Hey_You's Avatar
So the 2 psi is to check for leaks and make sure it's going where it's supposed to?
Old Nov 9, 2006 | 06:29 PM
  #73
kakarot's Avatar
yes, just to see if all works right. and if belt clears all, and that 2 psi is very hard to knock, so its basically fail safe point. even 0psi be better, but under 2 psi I would be able to hear any leaks and just be sure. That would produce almost 200HP.
I like being safe, doing crazy thing as puttign 10psi without any tuning and without chaking anything is kinda bad.
Dont worry I will supply a jumper so that 0psi be checked. So dont worry I make some steps for my future coustumers to make sure that nothing would go wrong.
Old Dec 2, 2006 | 10:28 PM
  #74
kakarot's Avatar
Okey all math and planing complete.
All crap figured out.
Now I need just the stuff to put together.
anyways only be recuired to cut 2 wires for tuning.
Old Dec 3, 2006 | 05:44 AM
  #75
Hey_You's Avatar
Who did you decide on for tuning? That's sweet that you got all the R done...now just gotta finish it up with the D, LoL. Oh man oh man...I want power! LoL
Old Dec 4, 2006 | 01:45 AM
  #76
kakarot's Avatar
it utizes stock map, no stand alone or piggy back.
Old Dec 4, 2006 | 04:00 AM
  #77
Hey_You's Avatar
So the stock ECU can reconfigure itself to handle about 6psi?
Old Dec 4, 2006 | 01:37 PM
  #78
kakarot's Avatar
with no mods to fuel system, just extra air, stock ecy can handle up to 3-4psi. with some mod to fuel system, it can handle up to 14psi
Old Dec 4, 2006 | 02:43 PM
  #79
Hey_You's Avatar
Ahhh...gotcha...
Old Dec 12, 2006 | 01:30 AM
  #80
Hey_You's Avatar
What would you use to get more fuel? Would you just use different injector...modify the fuel curve on the ECU, or chip it somehow?
