turbo
first off what turbo did you get? i assume you have an a4? i would post in the a4 section you will get lots more hits.
you need to be able to tune your car. using a chip or some kind of custom tune.
i ran a s-afc with my t3t4 in a 1.8. only problem was i couldnt controlle timing. also it was hard to get good data logs becuase the way my s-afc was set up it messed up the maf readings so i took it out and chiped the car with a custom tune. it ran a million times better
i have a mega squirt ...but i dont want to pull the engines original harness apart...i was thinking of getting another set of injectors and have megasquirt run those alone... i would machine extra injector bosses into the manifold. my only problem would be the timing...what do u think of this set up though ?
is there any one that makes a chip, tune or flash for your car. becuase thats the best thing. you get fuel, boost and timing. this extra injectors seems to much and will cause more problems with trying to get 8 injectors to work togeather using 2 different programs
yeah i know what u r saying...how much boost can i run before i need to alter the ignition maps....assuming i can set the A/F ratio right.i know tuning the extra 4 injectors would be hard ...i want to give it a try...i am worried about the timing though..i know the engine has 2 knock sensors but i know theres a limit as to how much timing they can pull...how much timing do chip manufacturers alter the timing?
Clos2010
Sep 3, 2013 08:15 PM
03a418tnate
Aug 10, 2010 08:07 PM
SupraSkylineSTI
Apr 2, 2010 10:46 AM
mr V8
18
Jun 23, 2006 03:21 AM
DickM
12
Mar 21, 2006 05:15 AM
