North East ME, NH, VT, MA, RI, CT, NJ, NY, PA
Audi b5 water leak from rain.
Old Sep 7, 2011 | 07:34 PM
o0hmikee's Avatar
Default Audi b5 water leak from rain.
I have a water leak problem passing through the footwell on my 1996 audi a4 2.8 quattro. I've read on several forums that this is a common issue with audis. This problem occurred when the hurricane passed last week and all the water build up around the battery started to leak through under the footwells. Now, is there a way I can drain all the water filled up under the battery? drill holes?
Old Sep 8, 2011 | 04:31 PM
dmaxn's Avatar
You have to physically clean out the rain train. Just remove the battery and ECU then clean any leaves and dirt you see in the channel.
Edit: Clean the sunroof drains too: http://www.audiworld.com/tech/ext61.shtml
Old Sep 13, 2011 | 08:39 AM
MARKANTO13's Avatar
If you reach down there you will pull out leaves. Blow it out with air. You'll be shocked how much **** come out.
Old Sep 14, 2011 | 06:33 PM
o0hmikee's Avatar
thanks guys I took the battery off and cleaned off the drainer. Now, how do I get to the bolt next to the ecu? I heard theres a drainer under there too?
Windward
Jun 23, 2014 10:42 PM
marka8
Oct 29, 2012 07:08 PM
dimaudia6
Sep 12, 2011 03:47 PM
Rayman740
Feb 8, 2007 06:12 AM
juandango
Oct 26, 2005 11:05 PM
