LightWeight Luggage? Traveling OverSeas!
Subscribe
Jun 27, 2010 | 11:44 PM
I am leaving for Ibiza,Spain September 14th 2010 to October 2nd 2010.
I will be there for 17-nights,I want to take (2) Pairs Of shoes and (1) Pair of Sandals.I really don't wanna wash So I wanna push for t-shirts,maybe few jeans & shorts.
I am looking to invest in Luggage Bag that Weight 10.0lbs Or Under.What do you guys think? For my carry on I am taking my DSLR.
Flight Info=Iberia
Luggage=50 lbs MAX
Maximum dimension for hand luggage
The maximum size must be 55cm x 40cm x 20cm (115 cm), including handle, pockets and wheels. Also:
* It must fit the measuring supports available in the check-in areas
* It must fit the closed overhead lockers installed for this purpose, or below the passenger’s seat.
* If your baggage is over size or overweight it will be taken from you at the boarding gate.
Reply
Jun 28, 2010 | 12:42 AM
I will go with Samsonite. Their newer stuff are light weight yet really sturdy!
Why don't you just go shopping over there instead of bringing a lot of stuff over? I'm pretty sure they have a lot of things you might be interested in. At the very least, you could always buy bunch of white T-Shirts incase you ran out of shirts to wear.
What are you gonna be doing over there anyway? Pursuing your DJ-ing career?
Edit: Did a really quick search, something like this should work for you: http://shop.samsonite.com/Samsonite-.../dp/B003IESHZ0 - it's actually pretty cheap too!
Reply
Jun 28, 2010 | 02:45 AM
I would also like to add that I am looking into carbon fiber materials and other lightweight materials to pack at the max for 17 nights.
http://cdn.overstock.com/images/products/L12541144.jpg
28 inches high x 17 inches wide x 12 inches deep (10 pounds)
This image has been resized. Click this bar to view the full image. The original image is sized 650x650.
Reply
Jun 28, 2010 | 02:54 AM
CF luggage? How much are you planning to spend?
Those things go from $2K all the way to $5K.
Reply
Jun 28, 2010 | 03:22 AM
That one is only $179.99 SHIPPED
Rockland Ritz Carbon 3-piece Hardside Spinner Luggage Set
Reply
Jun 28, 2010 | 03:23 AM
:Lightweight Polycarbonate ABS Hard Shell, Chrome
Rolling upright measures 20 inches high x 13 inches wide x 9 inches deep (6 pounds)
Spinning upright measures 24 inches high x 15 inches wide x 10 inches deep (8 pounds)
Spinning upright measures 28 inches high x 17 inches wide x 12 inches deep (10 pounds)
Reply
Jun 28, 2010 | 03:29 AM
http://www.luggagepros.com/antler-no...llercase.shtml
Weight10.4 lbs
Dimensions29.9" x 21.7" x 12.2"
• Rugged ABS Material
• Central locking trolley system that reaches 39" from the floor when fully extended
• TSA fixed combination lock
• PVC protective corner buffer to minimize wear and tear on the bag
• Fully lined interior with mesh pockets for maximum visibility
• Elastic interior tie straps to minimize wrinkling and movement during transport
• Molded side and top handle
Reply
Jun 29, 2010 | 09:29 PM
bump----
Reply
Aug 12, 2019 | 04:36 PM
Choosing a first-class suitcase is hard. The head is spinning from a variety of models, materials, sizes, and types. Plastic cases are usually more durable than fabric ones, they do not get wet and are easy to clean: just wipe with a cloth. Thanks to the solid body, it is possible to safely transport fragile items in a plastic case. I am now looking for a plastic suitcase, can you say anything on delsey luggage reviews?
Reply
Subscribe
