Liquid Detected in Lightning Connector
Old 08-27-2023, 03:34 PM
Bronks333's Avatar
Default Liquid Detected in Lightning Connector
Hey everyone, I've been having issues with my iPhone showing a "Liquid Detected in Lightning Connector" error. What's causing this problem, and how can I fix it? Any advice?
Old 08-27-2023, 04:03 PM
Pedro72's Avatar
Hi there! The "Liquid Detected in Lightning Connector" error typically indicates that moisture or liquid has been detected in your device's charging port. It's a safety feature to prevent potential damage from short-circuits. To fix it, first, make sure your phone is powered off. You can gently clean the lightning connector with a dry, soft brush or compressed air. Avoid using any liquid as that might worsen the situation. If the problem persists, I recommend checking out this detailed guide at https://wallyhome.com/liquid-detecte...connector-fix/, which offers step-by-step instructions on what to do. Remember, patience is key, as you want to make sure the port is completely dry before attempting to charge again.
Old 08-27-2023, 04:31 PM
Harry23's Avatar
They're great at absorbing moisture and can be placed in a sealed container along with your device overnight. Just remember not to put the gel packets directly on your device. In case the problem persists, it might be worth reaching out to Apple Support. They can provide further assistance or recommend an authorized service center. It's essential to tackle this issue promptly to prevent any lasting damage to your device.
Diego88
03-24-2023 10:41 AM
Diego88
10-06-2021 12:38 PM
fouraudis
08-29-2008 04:06 PM
Quick Reply: Liquid Detected in Lightning Connector
