2003 S8
Old Nov 17, 2006 | 09:57 AM
NYSKANK's Avatar
Default 2003 S8
Hi - I'm new to this site and I'm about to pull the trigger on purchasing a 2003 S8. Before I did I wanted to ask if there are any known problems, common or not so common, or any other things I should be aware of and check for that may cost $$'s outside of warranty before I negotiate and close the purchase. I'll be purchasing from an Authorised Audi Dealer so it will come certified and with a couple of years warranty etc.
Thanks in advance!
Old Nov 17, 2006 | 09:34 PM
Roadhawk's Avatar
Default RE: 2003 S8
Can't help you there regarding the S8 sorry - and not sure how many - if any S8 owners are here...awesome car BTW...Audis almost always have some problems (and you just need to budget that in....) - perhaps agoogle search might turn up some specifics...
Old Nov 18, 2006 | 11:24 PM
Baskin 4.2l's Avatar
Default RE: 2003 S8
I have a S8 motor in my car and the only thing you should need to think about is to make sure that the timing belt and water pump is good. Check to see If there is any oil around the cam seals. From that I don't know of any other issues body wise
Old Nov 19, 2006 | 10:37 PM
DevilS4's Avatar
Default RE: 2003 S8
The 4.2 seems to be pretty much bullet-proof. Anyone know all the differences between the S8 motor and a standard 4.2?
Old Nov 20, 2006 | 09:28 AM
Default RE: 2003 S8
The differences are
Different cams
heads
throttle body
intake manifold
air box
motor code
transmission and gear ratio
rev limit
manifolds
fast euro
Apr 3, 2010 12:13 PM
Stella Monkey
Sep 17, 2009 05:32 PM
deadmcdowell
Aug 30, 2007 03:13 PM
abacab
Mar 24, 2006 01:03 AM
rendezvous97
Jul 11, 2005 05:02 PM
