After Run Coolant Pump.
Old Apr 8, 2008 | 10:37 PM
godowninflames's Avatar
Default After Run Coolant Pump.
Dealer says coolant pump is leaking. What is the part number on this? and where can i purchase this other than the dealer? (if anywhere).
Thanks.
Old Apr 8, 2008 | 11:15 PM
Audi_Skydiver's Avatar
Default RE: After Run Coolant Pump.
I believe ECS tuning has them.
Josh
Old Apr 8, 2008 | 11:28 PM
Is this the same as the auxilary water pump?
Old Apr 9, 2008 | 12:06 AM
Well you have the main coolant pump that runs off your acc. belt then there is the after-run pump that runs once you turn the car off if it's over a certain temp. Which one is it? Your title says one and your post says another. ECS tuning sells both of them though.
Josh
Old Apr 9, 2008 | 11:10 AM
timtheguru's Avatar
ECS tuning has the Aux. Water Pump which is made by Bosch and located under the intake manifold, also if you buy it from there get the water pump hoses (there are 2) and intake manifold gaskets (need 2).
Old Apr 9, 2008 | 03:33 PM
The aux is the correct one i need. I ordered the pump along with the gaskets and hoses. How bad of a diy job would this end up being?
Old Apr 9, 2008 | 08:50 PM
Scott Long's Avatar
I hear it can be done but it helps if you have small hands.
Anyone know if you can bypass the pump when it starts leaking?
rtheriaque
Jun 6, 2011 08:55 PM
soupsun
Dec 24, 2008 10:13 PM
heisse_mkII
Jul 7, 2008 12:41 AM
Pson
13
Dec 29, 2006 12:48 PM
dudley doright
Nov 15, 2004 07:24 PM
