B5 s4- need info on sputtering/loss of power
Old May 28, 2009 | 06:47 PM
steelcitysfinest69's Avatar
Angry B5 s4- need info on sputtering/loss of power
Looking for info from more knowledgeable members than i... On my way home from work i noticed a major problem with my 2000 s4 (114,000 miles). I dont seem to have ANY pull through the RPM range where i normally felt my turbos the most. When i got off of the highway, i shut the car down, restarted and started down a back road. When i punched the gas and hit about 3000-3500 rpms i heard a erratic sputtering sound and lost MAJOR power!!!
After that i drove the car normally (not speeding) feeling no pull from my turbos. I heard them spooling normally but no thrust. When i smashed the gas, again, it sputtered when it shoud be boosting, again. Anybody with any ideas who would like to share??? Im heading to the STEALership tomorrow and would like to have an idea on whats wrong. Im thinking MAF, Coil packs, boost vales/piping or ... TURBOS are going!!!
Old May 28, 2009 | 07:33 PM
bottlecap's Avatar
my guess is maf
Old May 29, 2009 | 06:54 AM
bigern45's Avatar
could be busted tbb...
Old May 29, 2009 | 10:29 AM
thareals4's Avatar
sounds like a boost leak. Hook it up to a fogger.
Old May 31, 2009 | 01:01 PM
phitau09's Avatar
I bet its a bad MAF sensor. The car will drive normal until you floor it and then it will feel like power just cut out. I would compare it to someone hitting the brake really hard. I have had to replace a bad MAF at least 6 times in my life and every time, its the same trend. Drives normal till you wanna boost hard, then the power cuts out when you jump on the throttle. I dont think its a bad coil because when that happens the car becomes basically immobile. You can tell you have a bad coil when you pop the hood and get a huge whiff of fuel because all that gas is trapped in the cylinder not getting ignited. Good luck man. Let us know what you find out.
Old May 1, 2010 | 03:10 AM
dub 687's Avatar
i know this is a really old thread but mine has the same thing going on. would it be throwing a code if it were a coil pack?
Old May 14, 2010 | 01:47 PM
mys4.org's Avatar
Have you done any work to your car lately? Replaced any parts? I had a similar problem when I didn't gap my new spark plugs correctly.
Old May 15, 2010 | 01:38 PM
dub 687's Avatar
it finally threw a MIL, misfire cylinder 5 so I replaced the coil pack and its good. I need to do plugs though, what kind would you guys suggest? I have an EPL chip, would I have to gap it different?
Old May 20, 2010 | 01:19 AM
mys4.org's Avatar
OEM spec is .016 - .024 inches for spark plugs. There is a lot of wrong info out there but these are the correct range. Make sure to always check you gap even if the plug says pre gapped.
viliusruzas
B7 Models
Jul 3, 2015 01:14 PM
steven.whyte
Mar 15, 2012 11:53 AM
bigtm792
Mar 31, 2009 02:34 AM
NeXeA500
Jan 28, 2009 08:40 AM
S4rat
Aug 13, 2007 11:26 AM
