B6 S4 piggies DIY?
Old Mar 27, 2012 | 12:23 PM
jasontkennedy's Avatar
Default B6 S4 piggies DIY?
I have a 2004 S4 6MT
Okay, so I've searched google, VWVortex, and Audi Forums for info on a DIY for piggies for the B6 model s4. I know how to remove the downpipes (found that thread)
And I figured out a fast way to get the precat removed once I have the dp removed.
So I can remove the DPs and I can gut the precats. But from there, I'm just no connecting the dot with the CEL and the O2 sensors. I understand that there are 4 O2 sensors? 2 after the precats and 2 after the main cats? Do I simply buy a set of spark plug defoulers and put them into the openings for the precat O2 sensors? Do I have to move them closer to the main cats AND space them?? Should I get the VAST spacers instead?
I've read that you sometimes will get a CEL anyway, even if you space the O2 sensors.
If I go to the trouble of pulling my DPs and gutting them, what do I need to do to the sensors to avoid a CEL?
Old May 11, 2012 | 11:44 AM
darkside2303xxx's Avatar
i'm not sure exactly how you do it but i know JHmotorsports does it and they can also tune the ECU to not throw any codes with no cats at all, pre or regular. They did my piggies and ecu and no codes. They are very helpful with techincal questions. it will definitely be worth e-mailing their V8technician, they have helped me several times, customer or not.
Old May 12, 2012 | 08:15 AM
vtraudt's Avatar
In principle: de-foulers and tuning the rear o2 out are the common options.
On our other car (Cougar 2.5 Duratec), we followed a DIY describing to solder in some resister (IIRC) to trick the downstream o2 and deliver values it expects.
Don't know if our Audi's can be done this way.
Woodhead2k
Aug 1, 2009 01:47 AM
DraxeofDclan
Dec 18, 2008 08:46 PM
CamoA6
Jun 17, 2008 05:26 PM
Coop
Apr 25, 2007 10:19 PM
