Bad OS 2 !
Old Feb 4, 2006 | 12:05 PM
chebert69's Avatar
Default Bad OS 2 !
I have a question for u. When you have bad OS 2 is it possible that it's causing
some misfires ? My mechanic erase a code for to the ground OS 2 num 2 +
Misfires on 3 different cyl, sorry dont recall wich ones. Overall the car did not perform
like it should. I recently install a boost gauge and i cannot exceed 8 psi
(seems like the car is in safety mod). With the mods on my car i should reach 16-19 psi. + gaz millage sucks !
Would i spend some money on OS2 for nothing ??
TY 4 your help !
[IMG]local://upfiles/9918/DB9C9DAC47324BC68CB5C4FCA8E8B329.jpg[/IMG]
Old Feb 4, 2006 | 12:22 PM
techbod's Avatar
Default RE: Bad OS 2 !
you would probably be wasting money on a hunch, the problems you describe are more like MAF sensor, IAC, TP sensor but could be anything without the code its just a gamble, have the system checked again and take note of the codes
Old Feb 4, 2006 | 09:03 PM
dankhound's Avatar
Are you saying you had a code for o2 sensor bank 2 snesor2? Becuase sensor 2 is after the cat and gives no input to the ecm reguarding fuel trim or boost pressure. It only monitors cataytic converter effieciency.
Old Feb 4, 2006 | 09:42 PM
chebert69's Avatar
thanks im going to see my mech next monday and VAG the car ill take
noke codes and i get to you after with good info !
