Cam tensioner seal leak
I have an oil burning smell and I just replaced the valve cover gaskets and both cam adjuster seals so the tension seal is most likely the problem.
Can anyone tell me how much $$ it would be to replace a Cam Tensioner seal by an Audi shop on a B5 S4? Also anymore information about the tensioner seal, like is there more than 1? Is that the problem? Could it be anything else?
Thanks for any input you may have!
There is one cam tensioner seal per head. if you want to diy, I'd recomend getting a cam tensioner tool to remove the tension so you can wiggle the old seal out. there are 4 torx bolts that hold the tensioner down, 3 of which go through the seal.
make sure to clean the sealing surface before installing the new seal.
It is relatively simple to do, and you don't have to mess up your timing to do it.
I just got quoted 2,000 in labor because they said they would have to remove the cam shafts to replace the gaskets. Another 270 for timing belt as it will already be off. I'm don't know a whole lot about our engines but can follow instructions well, I am debating trying to do this job myself... What do you all think? Any suggestions are welcome. 01 s4 tip
lol, not quite. Here you can find a whole valve cover reseal kit for 90 with the cam tensioner seals... I'm sure if you look around you can find just the cam seals for about $20
OEM / Performance Parts for Audi, BMW, Mercedes Benz, Mini, Porsche & Volkswagen - ECS Tuning
call the stealership and see what they charge.
Thanks.
Kevin
