CEL with SSAC exhuast?
Old Feb 8, 2008 | 01:16 AM
profects4's Avatar
Default CEL with SSAC exhuast?
been looking all over, cant really find a detailed answer... anyone here running the SSAC down pipe and cat-back exhaust? and if so does ut throw a CEL? If it does how did you get rid of the CEL, and overall hows it going for you. Thanks guys
Old Feb 8, 2008 | 02:03 PM
typhoonfd's Avatar
Default RE: CEL with SSAC exhuast?
i have both the dp's and exhaust and i think it sounds great, but anyway on toyour question you should use cel elem from vast http://vastperformance.com/shop/inde...4c2a7e81868cebthat should fix you prob. you can also use 18mm long sparkplug non-foulers from pepboys but you have to use a larg drillbit to drill out the insideof the non-foulers alittle to get the o2'sthreads to get a good bite.hope this helps
Old Feb 8, 2008 | 02:33 PM
profects4's Avatar
yea i was looking at these..question is do i need all 4 or just 2... and then how do they work with the o2 sensors, do i need special ones? or they fit right in, and the CEL eliminator just restricts the amount it reads or what? thanks
Old Feb 9, 2008 | 12:57 AM
typhoonfd's Avatar
you just need 2 they go (post cats) down stream.the cele moves the o2's just out of the exhaust flow when they are extended out. what code are you getting with your cel? i still get a code now and again but i was told it's the up stream pass o2 thats bad. again keep in mind that the up stream (pre cats)o2's DO NOT need or get cele just down stream. hope this helps. you also may be able to find them on ebay, but i never tried and watch what you buy on there..let me know how you make out.
Old Feb 9, 2008 | 02:37 AM
profects4's Avatar
well the codes im getting now are 0102, 1137, and 1139 which two of them deal with the post cats and the other one is the MAF... so i wantedto get rid of the cats and i just wanted to see what my options were. It helped alot man thanks, but now i got to wait till they have em back in stock =(... hows the spool sound? and how many lbs of boost ya running with the exhaust?
Old Feb 9, 2008 | 07:47 AM
typhoonfd's Avatar
i dont know with just the exhaust im 2+ but im at about 22lbs. the spool sounds great from -10 to 5. after that all i hear is the motor from inside the car. ormy turbos are going to fail i dont know but boy it is loud. i am shure you can get the cele from some other online stores look in the faqs at the top of the s car model line. its at the very top, its by 2ks4.i do wish he would come back and post........by by 2ks4 [sm=boohoo.gif]here you go. o and get new oem s4 exhaust clamps i had probs with the old ones. let me know if you cant find them i will give you the site add.
https://www.audiforums.com/m_406711/tm.htm
Old Feb 9, 2008 | 05:39 PM
profects4's Avatar
thanks alot man.
Old Feb 9, 2008 | 10:28 PM
typhoonfd's Avatar
no prob any time. let me know how it sounds when your done.
murdox
Sep 19, 2012 01:22 PM
cshideler
Sep 12, 2011 10:36 AM
pokemonslimes4
Aug 1, 2011 02:41 AM
Mills
May 11, 2009 07:55 PM
CamoA6
Apr 11, 2009 04:42 PM
