Check Engine light on-01 Audi S4
Old Oct 4, 2007 | 11:49 AM
blaze420's Avatar
Default Check Engine light on-01 Audi S4
Well my check engine light came on this morning, so i brought it up to the dealership where i bought the car. It was a random/mutiple cylinder missfire. The car has about 77k on it could it be i need new spark plugs and wires? Also when im driving on occasion usually when cold the car hesitates how much do you think this missfire code has to do with that? The dealer reset the code and told me if i came back on hell look into it more...so hopefully something will be done with that. Another question is what kind of plugs and wires should i run on this thing...and how hard are they to change? Thanks
Old Oct 4, 2007 | 12:25 PM
2000Sforce.dtwaudi's Avatar
Default RE: Check Engine light on-01 Audi S4
our car does not use wires. It is a coil over plug. Your best bet is to figure out the problem and change that. Dont be a parts changer and waste your money.
Old Oct 4, 2007 | 12:28 PM
blaze420's Avatar
any advice on where to start with this problem....i pulled engine cover and checked the tbb and the lines running from the dv there doesnt seem to be any leaks...any other places to look for a boost leak or possibly a vacuum leak?
Old Oct 4, 2007 | 12:40 PM
techbod's Avatar
don't waste time just get the codes ( it a multiple misfire your on about ) and its probably coil packs but its just a guess without any fault codes
Old Oct 4, 2007 | 01:32 PM
vinni_01's Avatar
i had a similar problem at about 90k, it was multiple missfires, first intermitant, than steady, turned out to be a coil control module, diagnosis, module, and spark plugs, at the dealer was about $650, since than a had a random cylinder missfire, but thats it, no further problems, i was told it just happens once in a while, also the spark plugs are easy to replace, all of a half hour, remove plastic engine cover, 2 screws for each coil, than replace plugs, dealer use NGK platinums.
Old Oct 4, 2007 | 06:29 PM
2k S4's Avatar
Find out what the codes are, see if it's just one cylinder, or more. It can be a bad plug, bad coil, bad o2, bad egt, bad MAF, leaking injector, etc.....
Old Oct 4, 2007 | 10:14 PM
blaze420's Avatar
ok i have access to a Nemysis scanner( not a cheap one the $800 one)...but thats probably not what i need im guessing VagCom....correct? Also i should mention that i can feel the misfire when its cold but once the oil temp heats up it seems to go away...the missfire is intermittent. Also is there a way to check if my timing belt has been done....because if it hasnt im ganna do it soon my friend is a mechanic at a garage and were going to do it one weekend. I should mention that it looks like my bumper has been removed because it isnt lined up to factory spec(one end pokes out more on one side) thanks for all the help guys.
Old Oct 5, 2007 | 12:13 AM
ChumbaWumba's Avatar
i had a CEL a while back...turned out to be a bad EGT sensor...not sure which side...would this cause lower gas mileage??
shawn2444
Feb 18, 2015 10:17 PM
dsp
Dec 10, 2011 07:59 AM
doadea
Mar 15, 2010 04:56 PM
MrTigz5254
Mar 7, 2008 11:56 PM
