Clutch goin!!!!!!! SHIT
Old Nov 27, 2006 | 05:25 AM
4CE_FED's Avatar
Default Clutch goin!!!!!!! ****
My clutch started slippin yesterday i was on the freeway in 5th and got on it to get over and pass a civic[:@] ha and saw my RPM's jump up a little and then settle back down i was pissed. has any 1 replaced their clutch? what should i expect price wise and i'm planing on goin GIAC, Turbo back exhaust. Would i be safe goin with stock clutch or ? (any good clutch companies to go with?)
Thanks!
Old Nov 27, 2006 | 03:28 PM
Coop's Avatar
Default RE: Clutch goin!!!!!!! ****
perfect chance to upgrade. go oem rs or stage2 or 3...why not.
Old Nov 27, 2006 | 05:55 PM
Deb38's Avatar
yeah I have an 01 s4. my clutch went about 2k miles ago. I upgraded to an rs4 clutch. I also had to upgrade my flywheel because it got owned and they werent able to resurface it. i went with a lightweight AWE flywheel.
the rs4 clutch and flywheel from AWE were less $$$ than the dealers price for OEM. so that was nice.
Old Nov 27, 2006 | 06:29 PM
Brandon2000s4's Avatar
My clutch went out after having my car for 2 months. It cost me 1500 bucks and that was for the stock clutch replacement...sucks a nut
Old Nov 28, 2006 | 12:06 AM
DevilS4's Avatar
I'd upgrade at least the clutch while you are in there already. The clutch will only cost a few buck more for an upgrade from VAST or anyone else, the flywheel will add on a couple hundred more. Remember though that the labor is most of the job and if you don't do it now it will cost more in the long run.
Old Nov 29, 2006 | 02:23 AM
Deb38's Avatar
ya labor kicked my ***. 13.5 hour job is never going to be cheap. If you need a new flywheel, defintely go lightweight.
Old Nov 29, 2006 | 10:17 PM
S4evr's Avatar
yep mine is goin too 2 days after being chipped i noticed it slipping a little while in 4th 5th or 6th gear. im probably going to go with the rs4 clutch since its about $200 cheaper than a stage 2.
Old Nov 30, 2006 | 11:09 AM
DevilS4's Avatar
If any of you guys are in the central PA area, one of my techs at work does all my major work that I can't do without a lift. Clutch replacement $400 plus parts can't beat it and he's damn good.
incrementalg
Jan 16, 2010 08:43 PM
xav6ier
Mar 13, 2007 08:31 PM
new2me
Oct 30, 2006 06:56 PM
1BADS4
Oct 23, 2006 05:24 PM
hexion
Jan 9, 2005 07:55 PM
