codes help..where to start
Old Dec 17, 2007 | 03:13 PM
quattrolove's Avatar
Default codes help..where to start
2000 b5 s4 tiptronic 69000
P0741 Torque Converter Clutch Circ Performance or Stuck Off
P1116 O2 Sensor Heater Circ.,Bank1-Sensor1 Open
P1131 Bank2-Sensor1 Internal Rsistance too High
P1476 EVAP Emission Contr.LDP Circ Malfunction/Insufficient Vacuum
P0134 O2 Sensor Circ.,Bank1-Sensor1 No Activity Detected
Where should I start?
Old Dec 17, 2007 | 07:28 PM
2k S4's Avatar
Default RE: codes help..where to start
http://www.bentleypublishers.com/tech/audi
You might have a bad TC, but I would flush the trans fluid & do a few hail Marry's.
need new O2's might as well just replace both primary ones (right after the turbo)
Sounds like you have a leaking evap hose.
Old Dec 18, 2007 | 03:28 AM
For those 0xygen sensors I get them out from under the car? Is it possible I have an aftermarket torque converter if there is such a thing for an automatic?
Old Dec 18, 2007 | 01:06 PM
2k S4's Avatar
ORIGINAL: quattrolove
Nope, there behind the engine by the firewall. Yes, you can have a aftermarket TC, but it should not throw codes, as it's not electronic, it's mechanical.
Old Dec 18, 2007 | 02:30 PM
techbod's Avatar
I agree with all the other answers, the only one that threw me was P1476 EVAP Emission Contr.LDP Circ Malfunction/Insufficient Vacuum and that's because we dont have it in Europe.
the red line is a vacuum pipe for the secondary air system and its probably came loose and thats why there is insoficiant vacuum.
8-
To fuel system diagnostic pump -V144-
q
On USA models
[IMG]local://upfiles/12092/802B8A3F8D194D1B980DBE93F69211BB.jpg[/IMG]
Old Dec 19, 2007 | 10:53 AM
Bentley service dvd ordered. 02 sensors Behind the engine....yayyyy sounds like fun.
Old Dec 19, 2007 | 10:59 AM
techbod's Avatar
last time I encountered a similar problem it turned out to be the coolant temp sensor but good luck
matt.mahoney
Dec 6, 2012 07:55 AM
R. Johnson
Feb 10, 2012 05:37 PM
oscar7120
Oct 6, 2011 06:30 PM
LRpgulf77
Feb 6, 2010 08:45 PM
CamoA6
Apr 6, 2007 05:00 PM
