Crank Pulley
Old Apr 21, 2006 | 12:13 AM
1BADS4's Avatar
Default Crank Pulley
Hey guys, i found a crank pulley online for $173.00. Does anyone with a b5 s4 have a crank pulley? They said that it would add 8-18 hp for turboed cars. just seein if yall thought this was a good buy, thanks
Old Apr 21, 2006 | 01:27 AM
scarzie's Avatar
Default RE: Crank Pulley
Hmm i havent heard much about it, but i would like to find out. If it does work, that would be a pretty sweet and cheap upgrade!
Old Apr 22, 2006 | 02:35 AM
Roadhawk's Avatar
sounds fishy...and since i've never heard of anyone in the S4 world using such I would have my doubts...(don't you think folks would be all over it by now if it were so?..it sounds like potentially a very easy mod...)
Old Apr 22, 2006 | 05:50 AM
1BADS4's Avatar
Here is the link, check it out and tell me what you think. I already called to see how much installation would be, and they said about $100 (2 hours of labor)
http://cgi.ebay.com/ebaymotors/UNORT...QQcmdZViewItem
Old Apr 22, 2006 | 12:32 PM
tbr76's Avatar
If you buy the uinderdrive kit: Crank, Alternator, Power steering? you can see hp gains. The accessory pulleys are smaller thus spinning them faster "underdriving" You need a new belt as well w/ the kit because the newer pulleys are smaller.(I think) I have heard some bad things from this mod particularly if you have a powerful stereo system. You are overspinning the accessories and the alternator can become a problem. Just what I have heard....FYI.
Old Apr 22, 2006 | 03:21 PM
shelby69's Avatar
I read on some other cars that going to a solid pulley, instead of one with rubber in it (harmonic balancer), that it can damage the bottom-end. But, I do not know if Audi uses a solid one from the factory or not.
Old Apr 24, 2006 | 06:43 PM
AudiS4_190's Avatar
A crank pully will give you the horsepower no doubt about it........But it will also shorten the life of your engine. shelby69 is somewhat right. there has to be sometype of balance to them. If it's not balanced you will ware out the main bearings. And you will also get engine vibrations as well......To sum it up it's not worth the money and hassell to install it. And then to shorten the engine life.
Old Apr 25, 2006 | 02:44 AM
1BADS4's Avatar
K, thank u all for the info, i guess ill have to save up for sumthin else
pbrules10
Nov 15, 2011 04:09 PM
mexicali225
Dec 22, 2007 02:31 PM
Flip
May 24, 2007 09:44 AM
johnstef
Oct 21, 2006 07:31 PM
juice88
Jan 13, 2006 09:55 PM
