dash computer
Old Sep 20, 2007 | 09:29 PM
delsan19's Avatar
Default dash computer
I don't know what the little square box in between the speedometer and tach is called that tells you outside temp, MPG, miles till empty, etc. (onboard computer maybe)
Mine's in the shop for turbos or I would look up whatit is in the manual.
Anyway mine is not as bright as the rest of the gauges . It's a little broken up looking. You can read it, but sometimes it's a little hard to. Also tach needle isn't accurate. What is the cost to fix this? I want to ask you guys before I ask the mechanic.
Thanks,
delaney
Old Sep 20, 2007 | 10:52 PM
auditech79's Avatar
Default RE: dash computer
You need a new cluster, average cost is around $800 just for the cluster.
Old Sep 21, 2007 | 09:49 AM
sooks's Avatar
^^ true story... .and it is an issue..almost everyones i know loses lines in the cluster...mines getting pretty bad...its frustrating.
Old Sep 21, 2007 | 01:01 PM
CamoA6's Avatar
Try shokan ( www.shokan.com ) your better off calling though. 1-800-ALL-AUDI ( 1-800-255-2834 )
try finding a used one. as for the brightness, have you tried turning the trip reset **** under the speedometer?
Old Sep 21, 2007 | 04:42 PM
shawncumberland's Avatar
you can't use a "used" one... because I understand that you would not be able to calibrate it to match the mileage of thereplaced cluster.
I understandfrom when thecluster was replaced on the car I own, before I got it by the previous owner it was 680 bucks for the part alone, not including labor, and you have a 50 mile distance that can be travelled before thecluster locks itself and it is no longer adjustable.
Leppersmith
Apr 13, 2011 02:48 AM
Phat_J
Jul 28, 2010 06:45 PM
nickrohdes@gmail.com
May 12, 2008 10:36 AM
burak
Apr 12, 2008 04:38 PM
Piggy
Apr 4, 2006 05:42 PM
