debating on 2000 s4 need advice
Old Nov 15, 2007 | 10:50 AM
docp's Avatar
Default debating on 2000 s4 need advice
hi been reading quite a bit found a 2000 S4 nograno(excuse the spelling)blue 6spd on black, 130k car is in perfet condition all dealer serviced, price is 8500. all options except for navi. 1 owner all service records, timing belt and waterpump and clutch done at 90k, any input would be appreciated
thank you
Old Nov 15, 2007 | 01:23 PM
SourDieselS4's Avatar
Default RE: debating on 2000 s4 need advice
$8,500 is cheap. Its great that the t-belt and clutch have been done, that could save you some money. The service records from the dealer are a plus. If you can call the dealership that has been working on it and ask them about the mechanical condition fo the car. From the sound of your post its stock? If its unmodified, especially if theres no chip, that can save your turbos a little wear but 130k is getting up there and they will probably eventually **** the bed. Its quite expensive to replace them, when they do go, id reccomend replacing them with k04's thay are more relyabel. If you can bring the car to a mechanic you trust and have them look it over thats a very good idea. I have provided you with links to the FAQ and a buy guide ,dont know if you have allready seen them or not. If you havent check it out. The buy guide is very good. Best of luck
https://www.audiforums.com/m_406711/tm.htm
http://www.audisport-iberica.com/ftp...t-buyguide.pdf
Oh and its nogaro
Old Nov 15, 2007 | 01:35 PM
Burzum's Avatar
Shoot man for 8.5k with 1 owner and complete maintanence history I'd ****** that up before it's gone. Wish I coulda found a deal like that when I got mine.
Old Nov 15, 2007 | 02:06 PM
docp's Avatar
thank you so much guys i did read those posts, and it is bone stock just out of curiosity how much am i loking at to replace the turbos with ko4's
thank you again
Old Nov 15, 2007 | 03:49 PM
probably about $3000+ and its going to cost you just about as much for k03s
And 8.5 is cheap.... my s4 was $24,500 private sale with 53k miles about a year and a half ago
Old Nov 17, 2007 | 11:20 AM
S4speedfreak's Avatar
**** I wish I found a deal like that I got mine for a little over 13k with 86000m and shes a one owner car and It had all service done on it, I have had little to no problems because of basic maintainance. If it was taken care of thean maybe you've got a gem on your hands. If not, your goin in the pocket pocket pocket!!
Old Nov 19, 2007 | 12:08 PM
cbdsm95gst's Avatar
BUY AN 01+!
2000 S4, TOO many problems
Old Nov 19, 2007 | 12:45 PM
2k S4's Avatar
ORIGINAL: cbdsm95gst
BUY AN 01+!
Like what? There are 2 small things on the early cars that can be problematic. The "F" hose & the MAF. The hose can be fixed spending $20 on a Samco one, or buy a TIP there is no F hose. The MAF is just a replacement item, you can pick them up for $150, they do not fail very often. If you go K04's you will swap out the MAF.
If you get a really early S4, it will have aluminum uprights instead of steel, so the front suspension weighs much less, but uses a slightly different control arm setup.
Ink
Sep 11, 2010 10:52 PM
moosefist
May 27, 2009 12:44 PM
moosefist
adk0786
Aug 25, 2008 07:45 PM
ooantipostoo
Aug 31, 2007 11:35 AM
