Difference between an 04 S4 4.2 and an 04 A6 4.2?
Old Jan 23, 2013 | 10:34 AM
04A64.2's Avatar
Default Difference between an 04 S4 4.2 and an 04 A6 4.2?
As the title says, whats the difference in these two engines? Why does the s4 put out the few extra horses, and does the slight weight reduction vs the A6 really add up to that much faster acceleration?
As you may have guessed I have a 4.2 A6 right now, but I'm really getting interested in a S4. If I could only find one for a decent price within the state.
Old Jan 23, 2013 | 11:01 AM
TN69's Avatar
S-models need to be always a little bit more powerful that similar stock engines I would guess that only software is different?
Old Jan 23, 2013 | 11:24 AM
04A64.2's Avatar
Well, I've noticed the engines look somewhat different even for the same year so I thought maybe they had some different parts on there. The s4 seems to be much faster though, but only slightly lighter and more powerful.
Old Jan 23, 2013 | 01:40 PM
TN69's Avatar
You are correct. These might be differences in S4 engine: all-aluminium alloy 4.2 litre, 40 valve (five valves per cylinder) V8 engine (parts code prefix: 079.C, identification code: BBK), with chain-driven double overhead camshafts, roller-finger rocker arm cam followers, and included variable inlet camshaft timing. It also utilised a strengthened alloy crankshaft bedplate for the five main bearings, and a two-part baffled oil sump, and a light-alloy variable intake manifold (VIM), containing the sequentially actuated fuel injectors.
Old Jan 23, 2013 | 03:04 PM
Jeff-AudiUSAParts's Avatar
Former Sponsor
I show the same as above, but the US S4 had the BHF 344 hp cam chain (from the rear of engine) driven 4.2 liter. The A6 had the AWN 300 hp cam belt driven 4.2 liter.
jeitjet
Jan 3, 2019 04:09 AM
CoBra03TerminAtoR
Feb 18, 2008 12:48 PM
zippola
Feb 2, 2008 09:17 PM
nsx
Jul 10, 2007 12:49 AM
bluesnapper
Aug 11, 2006 08:15 PM
