Do I need new struts?
So I bought some H&R springs to lower my B7, I was told it would only lower about an inch, much to my delight it did much more than that. The back end is perfect, but the front isn't. My tires are so wide that it rubs into my fender when I go over bigger bumps, would new struts make the front end a little more stiff? What other options do I have, I have heard about possibly rolling the fender metal out a little, what do you all think?
with all lowering kits everyone recommends new struts. bilstein sports are usually the most recomended. your best bet tho is to roll the fenders. i bet you could probably rent the fender rolling tool from an auto shop or somethin. theres a way to do it with a pvc pipe and a floor jack but i fender roller is much less risky if you screw it up
Upper control arms. Factory equpiment doesn't have enough adjustment to bring the camber back within specs.
CPP UCAs
A cheaper alternative would be KMAC bushings which are basically an eccentric adjuster.
They are cheaper but dont have as much adjustment as the UCAs.
But it would be better than nothing.
KMAC Bushings
CPP UCAs
KMAC Bushings
