Down pipes on a older s
Old Jul 21, 2007 | 05:33 PM
mattbracing's Avatar
Default Down pipes on a older s
I have a 2000 s4 and i am thinking about putting down pipes on but i have heard that becuase it is allmost 8 years old i might break a bolt of the turbo and then halft to pull the motor to fix it.Also i was wondering if i was worth doing a stage 3 up gradeis worth doing toa car that has 130,000.I have haid the car for a few years and i havereplaced most every thing that wers outbut other than a APR chip i have not touched the motor
Any input would be great
Old Jul 21, 2007 | 09:48 PM
2k S4's Avatar
Default RE: Down pipes on a older s
YES< STG III is so TOTALLY WOTH IT! So isn't getting new DP's. Really unless you are a monkey, you should not break one of the studs. Just soak then with some PB Blaster first.
I would be S3 if it wasn't a motor pull & $2600 for the parts!
Old Jul 22, 2007 | 09:38 AM
Artrip's Avatar
Where in the world can you get the stage 3 parts for 2600 bucks? Are you including the fueling kit as well, or just a turbo upgrade?
Old Jul 22, 2007 | 12:24 PM
I have seen k04 for 2600 with out the fueling kit
Thanks 2k S4 for the help Who has the best DP
Old Jul 22, 2007 | 01:06 PM
2k S4's Avatar
ORIGINAL: Artrip
Just the K04's, inlet pipes & hardware, are $2600 from http://achtuning.com/
Fueling is another $1500-2500 depending on what you want & if you need to covert from the Bosh MAF.
mrbillmartin
Apr 1, 2014 09:43 AM
kaz98gt
Dec 16, 2010 01:37 PM
jakgtrey
May 20, 2008 11:02 PM
h8state
Apr 23, 2008 12:54 PM
SAudi
Mar 22, 2007 04:51 PM
