Drivers side Front tire problems
Old Nov 19, 2006 | 09:41 PM
02S4Avant's Avatar
Default Drivers side Front tire problems
I had the old front tire go flat last week. After i pulled it off i saw what is to be rubbing on the inside. Need help figuring this one out because iam putting the new shoes on her tommorow. I felt around and all that i could figure is that the bottom of the strut was rubbing agaist it in bumpy conditions? Also i found the cv joint boots are in two peaces on both sides throwing grease every where. this will be getting fixed also. If any one has had these problems please let me know as soon as you can. also take a look at the photo and you can see in the center of the word pilot is where the rubbing ends. Could the tire be rubbing against the spindle? i checked the other side and it is totally fine. oh one more thing, it sound like i have a wheel bearing going on the drivers side, it makes the whom-----whom-----whom noise when i am going 15-35.
thanks in advance for any help
Scott
[IMG]local://upfiles/23604/A0D51F963584419C831D5000CA3C7609.jpg[/IMG]
Old Nov 19, 2006 | 09:46 PM
02S4Avant's Avatar
Default RE: Drivers side Front tire problems
by the way i forgot to say that they are stock rims and 225-45-17 rubbers
Old Nov 20, 2006 | 02:04 AM
Coop's Avatar
crazy wear man. not sure. if it is making that noise, probably bearing issue. see if it goes away/ comes back when you turn the well left to right while driving. if you lean the car real hard to the left and it goes away then real hard to the right and it comes back, drivers side wb probably the culperit.
Old Nov 26, 2006 | 11:23 PM
02S4Avant's Avatar
Coop,
it happened to be four bent rims. i never thought it could of been this but it was. So i picked up four 18x8 Mille Migila MM-S's.
[IMG]local://upfiles/23604/79AC1FEF11A14DA9BF7EB6695AD3CA45.jpg[/IMG]
audiwetfoot
Jun 15, 2012 04:06 PM
xqae
Jan 3, 2008 01:16 PM
xqae
Jan 2, 2008 01:41 PM
bazzag
Aug 1, 2007 08:29 PM
justincr250
Jan 24, 2007 12:42 AM
