EBC and EFC? questions for b5 s4
Old Aug 26, 2007 | 01:37 PM
SilverAudiS4's Avatar
Default EBC and EFC? questions for b5 s4
Just curious has to a few questions for everyone...
What are your thoughts for electronic boost controler and eletronic fuel controler? not sure if thats what the fuel controler is called but oh well its 1 am...
Anyway, anyone running any of these? and prefrences? and mounting locations? and reasons why or why not to use them?
I was looking to get both and tune the car homebrew style but am a little unsure, so i just wanted a few opinions, tia.
Old Aug 26, 2007 | 01:57 PM
Boostfed13's Avatar
Default RE: EBC and EFC? questions for b5 s4
Get a chip from a reputable company. It costs about $6000.00 to replace your turbo's unless you do it your self which requires pulling the engine and replacing the turbo's and re-installing the engine.
If you just tweek the fuel and increase boost with an EBC I give your engine and turbo's 6 months to live.
If you are trying to save money it will be much cheaper to havea pro reprogram your ecu.
I have had good luck with INMOTION TUNING on my B5 1.8t and have heard good things about there S4 tuning which you can find on ebay for $175.00
Old Aug 26, 2007 | 04:37 PM
2k S4's Avatar
You really can't do that with the S4's ECU. The car will constantly be put into limp mod. If you have a EBC, & the car is in limp mod, it will run lean, but oh, you cranked up the fuel, well now the cam timing & ign timing is all off, & the car is bucking & surging, & the DV's don't have a clue what they should do.
If you want a faster car, chip it, then work on a turbo back. That should net almost 350hp & 400 torque (crank readings).
Stay away from any offbrand chip/flash in the S4, it's a very smart & very complex ECU. AWE, ASP, APR, GIAC, & MTM are all the top rated ones.
mblayton
Jan 7, 2010 07:35 PM
playboy00786
May 31, 2008 06:37 PM
zchb9
May 20, 2006 01:29 PM
portwolf
May 18, 2006 03:27 PM
VolcanicBlackA4
May 18, 2006 02:11 PM
