engine cleaning?
Old Nov 21, 2006 | 05:37 PM
2000audis4's Avatar
Default engine cleaning?
i just baught a 2000 s4. it has 74000km on it.. the motor needs to be cleaned what is the best way to do it..i dont want to fry anything.
Old Nov 21, 2006 | 05:42 PM
2000S4's Avatar
Default RE: engine cleaning?
I myself just got a 2000 S4, my engine is pretty clean but some spots need cleaning.
Taken from another forum I am on.
"O.K. I know I have been slackin' for a few weeks now, but I assure you I have had good reason. My house has been under heavy construction for a while and I have been knee deep in it!
On to business. This week’s topic is engine detailing. As most of you know from cruising to local car shows, nothing looks better than a nice clean freshly detailed engine. Lets start with the degreasing process; first get some Simple Green Automotive grade degrease and load it up in a spray bottle and spray some on to the engine, (Note: Let the engine cool down significantly before attempting to steam clean or power wash it!). Spray the cleaner on to the engine focusing on the metal components such as the heads, block and water pump. Try to avoid spraying the electrical components and any plastic pars on the engine. Degreaser is very caustic stuff and can and will melt wire looms and discolor plastic components.
Then let the degreaser sit for a few minutes and soak in, spray on some more if necessary. Then take the pressure washer and set it to a very low setting, or if you are at the local car wash set the dial to warm or hot water rinse and stand back at least 18†and begin the process of degreasing.
Lastly, fire the engine up for a few minutes to let it filter out any water that might of snuck in from the pressure wash. Then take an old towel or an old Absorber (synthetic chamois) and dry off the major puddles of water that have accumulated around the intake and the like. If you have an air compressor, gently blow off the remaining water making sure not to get to close to the engine and its components, “You don’t want to run the risk of blowing off any of the vacuum lines etc!â€
The next step is optional, you can take some Meguiars or Zaino plastic and rubber protectant and coat the rubber pieces such as the hoses, EGR valve for 98-02 LS-1/ LS-6, ASR and air box assemblies etc. Then stand back and enjoy your labor! Your total time in this will vary depending on how much detail you want to go into. Other factors to consider are polished aluminum parts under the hood that may require polishing to bring up the luster, chrome that may require some steel wool to remove surface rust, or stains. And for you die hard “I want my car to look original†fans, you can use some talc powder on the hoses to give them that factory milky powdered look.
I hope this helps some of you and will inspire some of you to clean the old engine compartment, because a clean engine is a happy engine. Thank you all for viewing this. Till’ next time, and remember if you think it looks good “Roll with it!!â€"
It's a write up for Camaros so ignore the specifics on them.
Or try this
http://www.autopia-carcare.com/inf-engine.html
Old Nov 22, 2006 | 01:34 AM
Coop's Avatar
i got some stuff from the doll-up guys at the dealer i used to work at called "green nitro". the stuff was simply amazing. just spray on and rinse off. wipe with rag in tougher areas, but i only had to do that on 1 spot. try to get you hands on some.
Old Nov 22, 2006 | 02:26 AM
S4evr's Avatar
i use simple green (very similer to the green nitro) and it blasts away the dirt. highly recommended.
jhuffman
Mar 1, 2010 11:22 AM
B5 Audi
Dec 11, 2009 08:17 PM
Emilgevor
Sep 5, 2008 08:05 PM
B5_S-LINE98
Sep 1, 2008 09:22 PM
akindy
Apr 28, 2006 03:56 AM
