Error Code, what does it actually mean
Old Jan 8, 2008 | 11:01 AM
winter001's Avatar
Default Error Code, what does it actually mean
Hi guys, its been bad times for the B5 S4 lately, the strange noise I was experience at 35-40 mph is now happening all the time and is definatly a metal rattling noise and is particularly noticable when I hit the clutch and today the check engine light came on. I went to autozone and had the code diagnosed it came back as P1113 Fuel Air Metering, but when I check the code against the Bentley guide the guide is calling it Bank 1 Sensor 1 Internal Resistance too High. What do these mean and which one would be correct? I am also assuming that the noise has something to do with it. Thanks in advance.
-Chris
Old Jan 8, 2008 | 11:16 AM
jrodin's Avatar
Default RE: Error Code, what does it actually mean
well, they gave you a generic code so the one in bentley guidethat you looked up is right.I dont know what it means but it probably has something to do with an o2 senser. So go ahead and have the code cleared and if there is a real problem then, the car will throw the code again. Most likely, the code was thrown by you roddin the **** out of it and it wont come back on. And the noiseis probably a throw out bearing if it is getting louder when you engauge the clucth. How many miles are on it?
Old Jan 8, 2008 | 11:19 AM
winter001's Avatar
So far there is 93647 miles on the car. I'm still a newbie to auto tech in general, what is a throw out bearing? And would it effect the drivability of the car, because so far other than the noise and the light drivability seems normal? Thanks
Old Jan 8, 2008 | 03:34 PM
godowninflames's Avatar
Your o2 sensors are going. Same thing happened to me.
Old Jan 8, 2008 | 07:50 PM
syxxty's Avatar
the throwout bearing is in the clutch and is what the pressure plate slides on to engage with the flywheel. Your O2 sensor code should not have much to do with your rattle. I do not know how many miles the S4 normally takes before the clutch or throwout bearing fails.
All.. How many miles did your last clutch take before it needed replacing?
DCAV8R
Jan 23, 2023 06:33 AM
aaceve7
Sep 7, 2012 01:08 PM
shaikha
Jul 2, 2008 04:39 PM
NewJ_A4
Feb 3, 2008 01:09 AM
mikehh
Aug 25, 2006 03:35 AM
