Exhaust Piping route? what u guys think.
Old Apr 9, 2007 | 05:31 PM
TKneedsS4's Avatar
Default Exhaust Piping route? what u guys think.
Im inbetween myself rihgt now.... i have gotten my piggie pipes done and now im going to be running open exhaust all the way back to a single Remus Silencer. (model 70TD 4.02" if any1 was wondering) and what do u think the better route would be..... Meet the piping up just after the DP's and run a single 3-4inch all the way back depending on if there is enought room for a 4inch which i dont think there will be.... or do i run twin all the way back till just after the rear wheels then meet up right before the silencer?
Performance wise i dont see there being much of a difference. im just thinking to keep less drone i should run twin all the way to the gack but i just wanted to hear youse guyses input or if any of u have seen or done this your self.
Old Apr 10, 2007 | 07:06 PM
hyperlight900's Avatar
Default RE: Exhaust Piping route? what u guys think.
props too you if you do the 3-4 in
Old Apr 10, 2007 | 08:04 PM
2k S4's Avatar
What do you want out of it? If you just want max flow, put in 2 2.5in pipes, it will flow a TON more & still give you some ground clearance.
4in is fine, but there isn't a lot of room, if you are lowered at all, it's going to hit everything.
Old Apr 10, 2007 | 09:58 PM
S4evr's Avatar
go with a 3.5" single all the way back.. you should get more flow than twin 2.25's. (combined area of the twin 2.25 pipes is 31.8 while the area of a 3.5" pipe is 38.5) plus the single 3.5 will look ***** under the car. It wont scrape much or at all either. I run a single 3" all the way back and have had no problems.
silverttq
Oct 2, 2008 01:12 PM
Dj Spiel
Feb 26, 2007 01:58 AM
greekA4
Aug 15, 2006 07:46 AM
rcons
May 4, 2006 02:33 AM
mach6261
Jan 20, 2006 05:07 PM
