exhaust time
Old May 26, 2006 | 04:43 AM
nukemdead's Avatar
Default exhaust time
decision time,
i took my car to an exhaust shope the other day to see about a custom exh, they said they cand to turbo back but can do a 3inch where the y connectes in the back-to a magnaflow or dynomax muffler w a tip. its only like 250 or 300 installed, is this worth it or should i shell out the extra couple hundred and get a kit from someone? basically what im asking is the performance going to be that big of a difference between a custom exh from the y back or a actuall from the cat back. there is only a couple of inches between the cats and the spot where the normal cat back goes and where the custom y would go, thanks for the help
Old May 26, 2006 | 03:09 PM
scarzie's Avatar
Default RE: exhaust time
FYI a turbo back includes downpipes (bolt directly to the turbo, thus going from the turbo, back as opposed to from the cat back). You will see better performance wiht a cat back, its the same idea as adding downpipes, there will be less restriction overall throughout the system, leading ot better flow of air, increasing power. What I dont understand is why they cant make a turbo back OR legit cat back, since it is done at custom shops all the time.
Old May 27, 2006 | 12:48 PM
Hano's Avatar
i'm gonna agree with scarzie. if it's a custom exhaust, they should be able to make a cat back. personally, i think it's easiest to get a exhaust system from some company, ie awe. and then put it in yourself. it's not that difficult of a job. takes a couple hours at most. and you get the gratifying feeling of doing a job on your own car.
Old May 29, 2006 | 07:35 PM
nukemdead's Avatar
thanks for the help. not sure what im going to do. i seperated my shoulder this weekend and the doc said i cant drive for six or so weeks
Ittiot_Mk1
Aug 29, 2013 10:26 AM
Balzyone
Apr 14, 2010 09:30 PM
hcaudikeed
Apr 7, 2009 05:00 AM
a4autocrossr
Jun 1, 2006 05:45 PM
swift_A4
Feb 23, 2005 05:30 PM
