fog lights
alright here's the deal.... i have a 2001 s4 and i am wondering how the hell you get to the fog light bulbs so i can replace them, they are both out... thank you in advance for the help
I was able to get my fogs out just my pulling those insert grills out on the front. They snap in so be careful not to break them. After that you should be able to reach around and remove the two bolts holding the fogs in.
As always watch out for that fan! It can kick on at anytime.
so do you just apply even pillung force on the horizontal plastic piece in the middle or is it better to do one side at a time... just trying to avoid ripping something off hard that may not go back in correctly
you don't have to pull the bumper off,on the left side of the fog light panel if you look inside there's two tabs that you can stick a small flat head screw driver, slide the screw driver inside the tab and put a little pressure towards the left like you prying it open and then just pull on the panel.Once the panel is off there's three philip screws holding the fog light in place, remove those unplug the light and twist the cover off the fog light. The bulbs are H7.
nize
Jun 21, 2013 01:16 PM
L_U_D_I_AAudi
Jun 3, 2012 04:09 PM
mypreludeisred
Aug 9, 2006 11:08 PM
lilman05
Apr 27, 2006 02:56 AM
lilman05
Apr 25, 2006 10:04 PM
