fog lights
Old Mar 11, 2008 | 11:13 PM
lecznar1's Avatar
Default fog lights
alright here's the deal.... i have a 2001 s4 and i am wondering how the hell you get to the fog light bulbs so i can replace them, they are both out... thank you in advance for the help
Old Mar 11, 2008 | 11:35 PM
Blue_S4's Avatar
Default RE: fog lights
remove bumper...not as difficult as it sounds
Old Mar 12, 2008 | 02:21 AM
lecznar1's Avatar
lol damn i thought i was gonna have to do that.... how many screws are there?
Old Mar 12, 2008 | 08:06 AM
Burzum's Avatar
I was able to get my fogs out just my pulling those insert grills out on the front. They snap in so be careful not to break them. After that you should be able to reach around and remove the two bolts holding the fogs in.
As always watch out for that fan! It can kick on at anytime.
Old Dec 5, 2009 | 04:34 PM
bps4's Avatar
Default Pulling the plastic cover to get to the fog lights
so do you just apply even pillung force on the horizontal plastic piece in the middle or is it better to do one side at a time... just trying to avoid ripping something off hard that may not go back in correctly
Old Dec 6, 2009 | 02:31 PM
bottlecap's Avatar
i kinda just pulled them both a little bit at a time on each side and then pulled it out evenly once it was almost loose. really easy task overall.
Old Dec 6, 2009 | 02:32 PM
bottlecap's Avatar
also think about upgrading to HID's, could be cool
Old Dec 10, 2009 | 06:53 PM
mys4.org's Avatar
HID have been done in the fogs. It's next on my list of things to do. I would suggest the 3000k to get a good clean yellow color.
Old Dec 13, 2009 | 08:49 AM
hotgue's Avatar
you don't have to pull the bumper off,on the left side of the fog light panel if you look inside there's two tabs that you can stick a small flat head screw driver, slide the screw driver inside the tab and put a little pressure towards the left like you prying it open and then just pull on the panel.Once the panel is off there's three philip screws holding the fog light in place, remove those unplug the light and twist the cover off the fog light. The bulbs are H7.
nize
Jun 21, 2013 01:16 PM
mypreludeisred
Aug 9, 2006 11:08 PM
