Fuel Injector Suggestions for K04 with 997TT Wheels
Old Dec 22, 2008 | 11:53 AM
seanmh's Avatar
Default Fuel Injector Suggestions for K04 with 997TT Wheels
I'm looking for suggestions for my KO4s with 997TT compressor wheels. I see a lot about 60 lb injectors. Where can I get these? Is there another unit of measurement than 60 lb? I see them measured in cc/min but not in pounds. Would you recommend more for the different wheels that I have or are 60 lbs enough?
Also, would I need a new fuel rail for this?
Thanks!
Old Dec 22, 2008 | 12:15 PM
getto301's Avatar
Try 10secS4, hes a very helpful guy 10secs4@gmail.com
He sells complete fueling kits at a great price, you should ask him what he thinks about it.
good luck.
Old Dec 22, 2008 | 04:46 PM
Deb38's Avatar
60#/630cc injectors. Skip on the 10secS4 tune.
Old Dec 22, 2008 | 04:57 PM
seanmh's Avatar
Deb,
Could you point me in the right direction of some places to find these? ECS Tuning only seems to have 430cc injectors.
Do you know if the 630cc will require a different fuel rail?
Thanks!
Old Dec 22, 2008 | 09:01 PM
getto301's Avatar
630cc from vast
http://vastperformance.com/shop/prod...roducts_id=117
and on the page it says the price includes the fuel rail, hope that helps
Old Dec 22, 2008 | 11:15 PM
phitau09's Avatar
vast is solid!!!!
Old Dec 23, 2008 | 01:11 AM
GenerationX's Avatar
They dont require a different fuel rail just small spacers under the rails mounting tabs, these small spacers can be bought cheap...
Old Dec 23, 2008 | 07:58 PM
twentyvalveb5's Avatar
Get the injectors your tune is designed for. If you'll be programming yourself, then yeah - the Siemens 60#ers will give you enough overhead. You'd be pushing the limits with 42#ers.
Although if you're homebrewing on K03 code, you won't be able to remove enough fuel using lemmiwinks to make the 60#ers work, unless you have a huge (90mm) MAF housing, but that would likely give you too low load and put you in the wrong part of the maps.
So, yeah, get the injectors for which your tune is written.
Old Dec 23, 2008 | 11:51 PM
Deb38's Avatar
Hey buddy. I noticed you got the axe from AZ. Nice to see you around some other forums.
Old Dec 24, 2008 | 12:07 PM
seanmh's Avatar
twentyvalveb5, this is where I don't understand the tuning aspect. I'm not sure what my car is tuned for right now. I bought it already converted. I got a list from some other users of where I can purchasing programs from but I'm not sure how to get it on my car.
