Fuel Injector Suggestions for K04 with 997TT Wheels
I'm looking for suggestions for my KO4s with 997TT compressor wheels. I see a lot about 60 lb injectors. Where can I get these? Is there another unit of measurement than 60 lb? I see them measured in cc/min but not in pounds. Would you recommend more for the different wheels that I have or are 60 lbs enough?
Also, would I need a new fuel rail for this?
Thanks!
Thanks!
Try 10secS4, hes a very helpful guy 10secs4@gmail.com
He sells complete fueling kits at a great price, you should ask him what he thinks about it.
good luck.
good luck.
630cc from vast
http://vastperformance.com/shop/prod...roducts_id=117
and on the page it says the price includes the fuel rail, hope that helps
Get the injectors your tune is designed for. If you'll be programming yourself, then yeah - the Siemens 60#ers will give you enough overhead. You'd be pushing the limits with 42#ers.
Although if you're homebrewing on K03 code, you won't be able to remove enough fuel using lemmiwinks to make the 60#ers work, unless you have a huge (90mm) MAF housing, but that would likely give you too low load and put you in the wrong part of the maps.
So, yeah, get the injectors for which your tune is written.
Hey buddy. I noticed you got the axe from AZ. Nice to see you around some other forums.
twentyvalveb5, this is where I don't understand the tuning aspect. I'm not sure what my car is tuned for right now. I bought it already converted. I got a list from some other users of where I can purchasing programs from but I'm not sure how to get it on my car.
