Fuel Kits?
Old Mar 3, 2008 | 11:53 AM
Avant13's Avatar
Default Fuel Kits?
I know my car will need this sooner than later... where to find? whats involved?
Old Mar 3, 2008 | 12:19 PM
SourDieselS4's Avatar
Default RE: Fuel Kits?
do you have new turbos?
Old Mar 3, 2008 | 06:24 PM
Avant13's Avatar
ko4's installed about 2000 miles ago
Old Mar 3, 2008 | 08:59 PM
Deb38's Avatar
awe
asp
apr
vast
ssp
homebrew
you got options...you buy it, you install it, you drive it.
do you have a turboback?
Old Mar 4, 2008 | 01:45 PM
ARIaudiS4's Avatar
yeah this interests me alot also.
I have a full exhuast on my car right now. piggie pipes along with AWE twin1. I am planning on installing ko4's in the sumerr.
what fueling kit will suplly me with the most power from the ko4's .. i know some audi s4's use hobrew fueling kits and with some body modifications they can be running 10's...
what are the time slips.. or power comparisions on awe, apr, or vast. those are the companies i am most confident with...
Old Mar 4, 2008 | 03:05 PM
sweeds4's Avatar
AWE and Vast seem to have then best performance out of the box setups.. APR is conservative, just like their chip/flash.
You then can get a custom tune from someone in your area, but for more $$.
I think AWE says they are around 460 chp with their fueling set up, manifolds and downpipes. so that's around 360 whp.
custom tuning will yeild higher numbers.
Those 10's are after custom tuning with K04's and gutted interiors. I am getting his fueling set up then he is personally going to tune it accordingly
Old Mar 4, 2008 | 10:44 PM
Deb38's Avatar
Jay ran an 11.1 with his Vast Setup, but he also has some other tricks up his sleeve.
If you want the most post you should homebrew it. You can tweek your setup to the most aggressive form you want. Most OTS kits are designed more around daily driving ability.
My homebrew kit is very agressive but I am still able to drive around with it on a daily basis. On pump with a full exhaust I should be sitting around 400whp.
The reason why APR is so "conservative" is because of the difficulty to tweak their file. Marc has been able to do so and has had good results.
Old Mar 5, 2008 | 09:56 AM
sweeds4's Avatar
ORIGINAL: Deb38
What size MAF and injectors are you running? Ya marc has had good success on his APR file, but still can't wait for his other file
Old Mar 5, 2008 | 04:17 PM
2k S4's Avatar
FAQ, read it.
Old Mar 6, 2008 | 01:26 PM
Deb38's Avatar
ORIGINAL: sweeds4
ORIGINAL: Deb38
85mm MAF with 630cc (#60 Mototron Injectors)
ECS Tuning
Feb 20, 2014 12:08 PM
ECS Tuning
S4
Feb 20, 2014 12:07 PM
